Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 10:47 AM
flashart24's Avatar
flashart24 flashart24 is offline
flashart24 is starting off with a positive reputation.
rust in fuel
My drain water light keeps coming on and when I get down there to drain it rust is in my fuel. I think maybe this is what is setting it off. I just put the upgraded drain plug in. When I took the crappy factory one out it was rusted also. Is this where the rust was coming from? If so will it clear up or am I going to have too buy new filters now?
  #2 (permalink)
Old 11-02-2009, 11:03 AM
BPofMD's Avatar
BPofMD BPofMD is online now
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
The FIRST thing I would do is change the filters!! But you also MUST find out where the "rust" is coming from. I thought we had plastic tanks so I haven't a clue where/why you have rust.
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #3 (permalink)
Old 11-02-2009, 11:27 AM
gearloose1 gearloose1 is offline
gearloose1 is starting off with a positive reputation.
If the fuel tank is from factory, the diesel tank has to be rust resistant.
That is, made of aluminum coated steel (factory), or if it is an aftermarket, either stainless steel or some non-rusting material.
If you have a lot of rust... the first thing to do is to check it is a real factory tank, then the order of suspects are:
- got a bad tank of fuel from somewhere.... loaded with rust
- the coating has been breached (can only tell by visually inspecting an empty tank with a camera
- in any case, drain, replace the fuel filter, and purge the tank clean first.
Then go after your suspects.
  #4 (permalink)
Old 11-02-2009, 12:19 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Quote:
Certain models were equipped w/ steel tanks and Ford issued Broadcast messages about them rusting. Others had plastic tanks installed.
What year, model, etc is your truck.
Also - where do you buy your fuel.
Don't let your filters go too long before changing as BPofMD said. Your injectors could be damaged.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #5 (permalink)
Old 11-02-2009, 01:10 PM
flashart24's Avatar
It is a 07' with 44,0000 miles. The filters probably don't have but 7,000 on them.We have set monthly records here for rain fall every week . 18" just last week . Maybe it is coming from the underground tanks at the station.If they keep there rust will they drop this outrageous price of $2.72 or is that included with the price?
  #6 (permalink)
Old 11-02-2009, 01:41 PM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
05 S.D.'s have a polyethylene tank and therefore can't rust. I would assume that yours is a plastic type tank also and you probably got a bad load of fuel.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #7 (permalink)
Old 11-02-2009, 02:01 PM
firemanpat29 firemanpat29 is offline
firemanpat29 is starting off with a positive reputation.
are you sure its rust and not red clay? I had bad fuel twice that was loaded with water and red clay. change the filters, you dont want to be stuck on the side of the road because of a plugged filter. I think it is easier and way safer to change them where and when you want, not on the side of a highway, in the rain, with your favorite shirt on.LOL
  #8 (permalink)
Old 11-02-2009, 02:28 PM
bismic's Avatar
Injectors will be damaged quickly if the fuel pressure drops below 45 psig.
__________________
Mark
  #9 (permalink)
Old 11-03-2009, 08:00 AM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 is gaining momentum as a positive member of FTE.
Quote:
Bismic,
Do you know where I could find out about models that experienced rusting issues with the steel tanks?
Thanks
__________________
Greg
2006 F250 SC SB ESOF FX4 XLT 3.73LS; BF Goodrich All-Terrain T/A KO 265/70R17; Diesel Site Coolant Filter; Shell Rotella T Synthetic 5W-40; WeatherGuard Tool Box; Stanadyne Performance Fuel Additive; Brand Motion iPod Adapter; Line-X Bed Liner; Leveling Kit; B&W Gooseneck Hitch
  #10 (permalink)
Old 11-03-2009, 09:16 AM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen is gaining momentum as a positive member of FTE.
the filler neck is steel even on the poly tanks on the 250/350's. on my 05 the neck was rusted so bad it was flaking off in chunks. That was in Feb 07 when i bought it, so it is def another source to consider and inspect.
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
  #11 (permalink)
Old 11-03-2009, 09:28 AM
bismic's Avatar
Quote:
Originally Posted by Cowboy65 View Post
Bismic,
Thanks
I have it somewhere - I will look for it. I was thinking it was mainly chassis trucks, but not sure.
__________________
Mark
Tags
diesel , ford , fuel , rust , tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
