Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 11-08-2009, 09:51 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
i'm sure the pump wont be taxed nearly as hard with just stock programming but those 2's will still demand more with the bigger nozzles so you may still see abnormally high readings. it may take a long hard pull up a hill to see it climb though
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #62 (permalink)
Old 11-08-2009, 09:53 PM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE.
I'll test it and report back
__________________
97 F250 7.3PSD X-Cab, SWB, 4X4 5spd, 4.10gears, 3.5” DP, 4” Exh.,BDP 140v IDM,CCV,HPX,6637mods
Rosewood 180cc Stage II's, DP Tuner Live Tuned, Modded H2E, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #63 (permalink)
Old 11-08-2009, 10:06 PM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
i hope jim posts his thoughts on this, BUT my injectors werent in any sequence of how they ran. sometimes it would start great, other times it would idle rough at start up until i revved it a little then it would idle fine. sometimes it would miss @ WOT, but never in 2nd gear only in 3rd and would most of the time clear up in 4th, but did act up in 4th a few times. and then sometimes it would run great @ WOT and not miss or anything. sometimes it would miss in economy program under about half throttle through the gears. then sometimes it wouldn't. once i got my tuning i never did put it in tow program til like a month and a half later and as soon as i started driving it in tow it started missing making me think it was the tuning. apparently not b/c it doesn't even think about missing now. not saying the HPOP isn't your problem, just keep all this in mind just in case. also, the miss that cody has in his truck is due to his tuning i believe with his 180cc stg 2's. not sure if he got that fixed, but i think it was something about how it was tuned for the HPOP he is running. not possitive though
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #64 (permalink)
Old 11-08-2009, 11:16 PM
ah, the joys of modding trucks...lol nothing ever gets easier
__________________
  #65 (permalink)
Old 11-08-2009, 11:26 PM
yup but nothing gets funner!
__________________
  #66 (permalink)
Old 11-09-2009, 01:07 AM
don77's Avatar
don77 don77 is offline
don77 is starting off with a positive reputation.
mine runs rough and shakes and no power tell warm i asume its injectors anyways good luck
__________________
its the best
96f250 psd 280000 miles e4od with Hayden Automotive 1015 - Hayden Fluid Cooler 10k mod
BB mod 60 psi filter mod
3" down tub and opened cat muffler delete
autometer trans gauge
  #67 (permalink)
Old 11-09-2009, 07:29 AM
Well I did some more AE this morning on the way to work.
I am sure I got some funny looks from driving with a bright screen shining in my face before the sune came up. LOL
I tried the Stock setting and should I say it absolutely SUCKS!!! But that is just because I like the power, no problem with the tune. It told the tell. The ICP % went to 40% and flatlined and the ICP psi went to 2500 and flatlined. Both stayed there while I was on it. so apparently the pump will hold 2500psi but that is all.
Man the stock setting should be outlawed! It is quieter though, and talk abou slow to pick up speed. WOW
I believe the issue is pump. But why is it that Jim seems to think it should fit the bill? Please post up Jim.
__________________
  #68 (permalink)
Old 11-09-2009, 09:13 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
Neal, if I'm getting into a camp site late at night or leaving early in the morning I use the stock setting, it is quieter!
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #69 (permalink)
Old 11-10-2009, 01:55 PM
I just receieved an e-mail from Jody, confirming what I figured.
He does change the programming to allow for it to ask for as much as 85%.
I am definately overworking that pump real bad.
Thoughts anyone?
__________________
  #70 (permalink)
Old 11-10-2009, 07:19 PM
yes, get a bigger pump!!!!!! lol
__________________
  #71 (permalink)
Old 11-10-2009, 08:20 PM
I am so NOT an expert but based on what mine has done, I would say bigger oil.
__________________
Glenn
  #72 (permalink)
Old 11-11-2009, 02:01 AM
dual adrenaline HPOPs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________
  #73 (permalink)
Old 11-11-2009, 06:26 AM
Quote:
At the price they used to be that would have been possible. But talk about insane amounts of oil!
You are on the right track though but I don't believe Adrenalines are in the future. I was thinking more along the lines of 15ฐ pumps.
__________________
  #74 (permalink)
Old 11-11-2009, 08:02 AM
redone1 redone1 is offline
redone1 is starting off with a positive reputation.
would dual adrenalines be overkill or even possible?
__________________
1997 F-350, 4X4, Standard Cab, Long Bed, 4.10's
DIY 6637, 3" DP, 4" straight exhaust, True-Cool Tranny Cooler, RDS Stage 2's, PHP Chip, Guages: Exhaust-Tranny-Turbo
  #75 (permalink)
Old 11-11-2009, 06:40 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Dual 15's????
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
Tags
150 , 2000 , diesel , f150 , f250 , f350 , ford , heavy , hill , hills , jerking , load , misses , towing , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
