Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 11-03-2009, 08:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is online now
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
78% is crazy!!!!!!!! your pump is overtaxed. the ipr is basicly closed trying to buidl pressure. i would bet that if you lug those hills with your big load you will see the icp drop off or fluctuate. hpop is still my educated guess
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #32 (permalink)
Old 11-04-2009, 07:28 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE.
I believe I agree with you Joe. That is a crazy high number. That also was just a quick burst and it held the pressure for that short time. However I agree that if I were to watch it while towing that hill the pressure would drop off.
Now I am just guessing...
The pressure starts to drop off to the injectors. I loose atomization in the chamber due to this. Then I loose a little power due to less atomization then as the pressure drops the injectors are unable to fire or fire very weak for a split second and gives me that "Jerk". It stumbles and picks back up again only to just have this cycle repeat. All this happens very quick though causing that jerking/bucking feeling.
Does that sound somewhat close to what is happening?
I would like DZLJIM's thoughts on this too. From an injector pro point of view.
FWIW, I have been talking with Joey at Terminator and I believe I may go that route. I feel very confident that a dual pump system will take care of my problems. I am thinking dual 15° pumps, whadya think?
__________________
97 F250 7.3PSD X-Cab, SWB, 4X4 5spd, 4.10gears, 3.5” DP, 4” Exh.,BDP 140v IDM,CCV,HPX,6637mods
Rosewood 180cc Stage II's, DP Tuner Live Tuned, Modded H2E, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #33 (permalink)
Old 11-04-2009, 10:09 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
What would a set-up like that cost? Does Bob at DieselSite say the adrenaline will not supply enough oil?
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #34 (permalink)
Old 11-04-2009, 11:06 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is online now
FOREIGN GURU
1996 Ford F-250
RÖENTGEEP has a good reputation on FTE. RÖENTGEEP has a good reputation on FTE.
Talking
Quote:
Glenn,
I will buy your adrenaline, DONT WORRY. LOL.
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 143K.
DIY intake and exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*.
«Primum non nosere»
  #35 (permalink)
Old 11-04-2009, 11:55 AM
Bob said that the adrenaline will be at the top end of it's capabilities. It is mainly designed for stage I's and maybe Stage II's. I have 180 II's and a few other mods.
I was probably going to send him two HPOP's and let him build my pump setup from that. He doesn't advertise prices on that just the full kits and the kits where you send him one. Contact Joey for pricing.
__________________
  #36 (permalink)
Old 11-04-2009, 01:20 PM
Roentgeep, I only worry about making the next mountain grade, lol. So far, I've done really well with what I've done to the truck, thanks to this site. Neal, I only went with the 130cc babies from Beans, your 50cc over that. You are probably are over the edge, or near it. Your smart to be thinking ahead, I wish now I had gone with the statge 1's. I really do have all the power I need but a guy always thinks of having "MORE"!
__________________
Glenn
  #37 (permalink)
Old 11-04-2009, 02:59 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
Talking
Ok, Im totally agree with you in everthing you wrote.
__________________
«Primum non nosere»
  #38 (permalink)
Old 11-04-2009, 04:14 PM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
Why not dual adrenaline pumps?!?!?!?!?!?!?!?! hahahahaha. go big or go home right? I wanna see any of us use that much oil... LoL
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #39 (permalink)
Old 11-04-2009, 06:27 PM
Quote:
Now, if I could only get my wife to 'totally agree' with me, then I would be all set!!! lol
__________________
Glenn
  #40 (permalink)
Old 11-04-2009, 06:47 PM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
Are you sure you read the IPR duty cycle correctly? The OBS will only see a MAX of 54%, the Super Duties will go to 65%. So something doesn't sound right there.
FWIW, 180cc Single Shots use the same oil as AD codes which use a stock 17* pump. Ok, well, Stage-2 180's will empty quicker so they might need a little more oil. But I bet with good tuning you would be fine with a single stock 17* pump.
If I only had Stage-2's, I'd stick with a single pump.
It could also be possible that an injector or 2 are letting oil pass at a certain speed/rpm/oil psi. But if it only does this while towing, then that's perplexing, it shoudl be consistant empty too.
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
  #41 (permalink)
Old 11-04-2009, 07:29 PM
so this tells me that an adrenaline isn't as cool as i thought it was..
run another test on that thing neal. CCT turn up anything???
__________________
  #42 (permalink)
Old 11-04-2009, 07:48 PM
i have never seen a 7.3 go over 54 percent either. and the only time i have seen that happen is on "no start" situations that are oil leak related.
__________________
  #43 (permalink)
Old 11-04-2009, 09:36 PM
I will do more date logging but th enumbers were very high.
FWIW, 180cc Single Shots use the same oil as AD codes which use a stock 17* pump. Ok, well, Stage-2 180's will empty quicker so they might need a little more oil. But I bet with good tuning you would be fine with a single stock 17* pump. I run a stock 17 pump right now. it does good for DD but it will set a CEL real fast.
These numbers were obtained empty and only on a short burst. I will do more data logging this weekend.
Quote:
That is my thought as well.
Quote:
__________________
  #44 (permalink)
Old 11-05-2009, 07:24 AM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
I agree with that Neal. I'm definitely in the same boat as you are... Thanks for doing all this research! Lol.
I would think a single pump would handle it, but I guess we will have to man up and get electric fuel as well.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #45 (permalink)
Old 11-05-2009, 08:07 AM
Yup. This really confuses me now. I hate it when I get these answers when I post something. Not that they don't believe me or anything. But I know I saw those numbers but I didn't get a chance to record them, so it is like it never happened. LOL
I am definately going to record it and if it shows the same numbers again I will post it. Then maybe we all can diagnose this issue some more.
Jim, when you said an injector or two may be letting oil pass. What did you mean by this? Where does it pass by? Thru the injector or do you mean the o-rings?
Please explain some more.
If I have an issue I need to know and I want to fix it right now.
Thanks for your input.
__________________
Tags
150 , 2000 , diesel , f150 , f250 , f350 , ford , heavy , hill , hills , jerking , load , misses , towing , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
