Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 09:25 AM
AndeyHall's Avatar
AndeyHall AndeyHall is online now
AndeyHall is starting off with a positive reputation.
1 Issue, 1 Question
OK, so you may want to print this out and read it when you have some spare time because I just posted this and realized how long it was. Please don't not read it because it is so long though, because I really need to get this issue figured out. Thanks in advance for putting up with the super long post.
First off, the issue...I recently traded in an '04 6.0 with 144k miles with a cold air intake and straight pipes for a '03 6.0 with the sames miles, and the dealer said that he wanted to keep his trucks stock, so if I wanted he would let me exchange my '04s straight pipes and intake with the '03s stock exhaust and intake. So now my '03 has straight pipes and a cold air intake but no other mods. On a side note, now that I've driven this '03 and some of my other friend's 6.0s, I think my '04 was chipped and the guy I bought it from didn't tell me, because it would move so much faster than any other stock 6.0 i've ever driven, especially my new '03, and it also idled a lot louder. Another difference I noticed was in the exhaust sound. My '04 with straight pipes sounded like it was putting out a ton of air at the tail pipe when idling, and when you get on it real hard, the exhaust would start that popping noise like any V8 does with straight pipes, but the whistle from the turbo wasn't as noticable (but the turbo was working fine). On my '03 however, there is a little less of the air sound at the tail pipe, but for the most part it's the same, but the whistle is a whole lot louder when you hit the gas, and if you stomp it there is no popping from the exhaust, just a loud rumble almost like my '04 would do right before the popping. Also, not near as much pick-up as my '04. I know this is getting longer than I had planned, but please just bear with me...my '04 also would not put out hardly any black smoke at all, no matter what, it would only put out a quick little bit right when you hit the gas, but only if you floored it. This is my main issue right here....my '03 is a completely different story. I just noticed this the other day when I was getting on it pretty good going up a hill, I just happened to glance in the passenger side mirror, and smoke was POURING out, thick and solid black and steady as you please. At first it was kinda cool because I was always somewhat disappointed that my '04 couldn't do any at all, so I would play with it around town, punching the gas when a car was tailgating me and just gassing them. But then I started noticing some things...if I floor the gas, it doesn't smoke right off. The smoke starts very thin at the high rpms of 1st gear, then when it shifts into second it is thick and heavy black smoke and barely thins out as the rpms get higher, then when it shifts again it's thick and black again and again barely thins out as the rpms get higher, and does this for ever gear until the last gear it will finally quit and the truck is taking off pretty good. But then I noticed another thing...if I stomp the gas real hard and it shifts down into 2nd, 3rd, or 4th gear, or even when flooring it from a stop, it will start taking off real hard like it's supposed to, and of course the smoking starts as usual, but then all of the sudden the throttle will start bogging down for a few second and then pick up and then bog down again and then pick up again. Also, when it boggs down, i've noticed that the smoke is EXTREMELY black and thick at these times. Now up until this weekend the smoke has been fun because I could control when it did it and it wasn't too big of an issue. But then this weekend on I was on some steep mountain roads heading up into Asheville, NC and if I tried keeping the truck up to speed, everyone knows how it will sometimes downshift if the hill is steep enough and run some high rpms, and it did, and the smoke was uncontrollable. If I let off the gas enough to keep it from smoking, I couldn't keep up my speed on the hill. Also, like I mentioned before about the throttle bogging down, if I tried hitting the throttle just enough to keep up speed on the hill, the smoking would start, and the throttle would pulse in and out, almost as if I were flooring it and then letting completely off over and over. This is kind of concerning me because I am a broke college student who can't really afford any huge repair bills (which I know diesel engines can easily dish out), and I have always done my routine maintenance myself regularly to keep from having any big issues like this, but I have a feeling this issue was present in the truck before I bought it. The only problem is that I bought it from a used car dealer "as-is" so there's really nothing I can do about it as far as the dealer is concerned. But does anyone know what my issue could be? I know that was a super-long description of the problem, and I'm sorry for that, I just wanted to make sure that I got all of the details in there to keep from having a ton of questions about other possible symptoms. So anyways, if anyone knows what my issue would probably be, I would really appreciate any input.
Now for my question, but don't worry, it's short and sweet unlike my issue. Does anyone know where I could find some install instructions for a engine block heater? I know my truck already has the element in the engine block, I just need to get the cord from my dealer and install that part. Is it very hard to do? I have a Haynes Repair Manual for my truck, and tried finding the info in there but couldn't, so if anyone knows where I could find some info on this, that would be great.
Again, I really appreciate any input that anyone may have for my issue or my question, and if you've made it this far in my post, Thanks a ton for putting up with my super long post.
Last edited by AndeyHall; 11-02-2009 at 09:32 AM. Reason: Realized how long it was.
  #2 (permalink)
Old 11-02-2009, 09:49 AM
JaySVX's Avatar
JaySVX JaySVX is offline
2004 Ford Excursion
JaySVX is gaining momentum as a positive member of FTE. JaySVX is gaining momentum as a positive member of FTE.
Are you sure you don't have the cord? It could be hiding. Mine was, took me a bit of searching to find it, actually went to where it plugs into the engine and saw it there, then followed it forward. Pretty sure all 04's came with it.
As for your issue... Separate that into paragraphs. It's unreadable as it is. Collect your thoughts, put each in it's own paragraph. That way people can read it, and you'll get the help you're looking for.
__________________
2004 Ford Excursion 6litre PSD
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
Quote:
Originally Posted by Maxium4x4 View Post
I would drive 1,500 miles out of my way rather than to walk through the front doors of any WalMart, OH look! TruckNutz isle 5
  #3 (permalink)
Old 11-02-2009, 09:54 AM
Egmonster Egmonster is offline
Egmonster is starting off with a positive reputation.
JFC!!! That was a long one man. To answer your block heater question:
Diesel Technician Society
I will keep reading your first part. LOL
Edit: read your first part a few times. I am new with the 6.0. Black smoke is too much fuel/bad atomization or not enough air. Turbo??? Could really be a bunch of stuff that causes that. I am sure a 6.0 expert will chime in with a better answer.
  #4 (permalink)
Old 11-02-2009, 11:00 AM
AndeyHall's Avatar
I understand. When I get a little more time later this afternoon I'll definately do that. But if anyone could just try and get what you can out of it for now that would be awesome. Thanks for the help so far guys.
oh and i guess i didn't make it very clear in my long paragraph, but I HAD and '04 and now I HAVE and '03. So did those come with a cord? Sorry for the confusion.
  #5 (permalink)
Old 11-02-2009, 11:15 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
First of all (other than hard reading the post), you really don't want that CAI on the 6.0! It will dust your turbine it will cost you more than you have to repair it.
The black smoke is UNBURNED fuel. If you don't have a lot of $, the price of diesel fuel is too high to be throwing it out the tailpipe.
As the truck was sold in PA (it was, wasn't it), it probably does NOT have the cord for the block heater. The cord is much cheaper from an International dealer than a Ford dealer...International made the 6.0 for Ford.... so you can save by buying one there.....BEFORE you go to buy it, do as the others above say and LOOK for it first. The previous owner may have already installed one.
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #6 (permalink)
Old 11-02-2009, 11:25 AM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
I will second that and also add that the OP is getting for all intents and purposes no performance value from the intake. Stock, when it comes to the air filter on the 6.0, is actually very good until you really start doing the performance mods and just tuning/chipping it isn't going to be enough to qualify.
That's true, however, with the issue of bogging down and lack of power, I would also have him look for an EGR related issue. Crack in the up-pipe(or y-pipe) or a problem with the valve itself.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #7 (permalink)
Old 11-02-2009, 07:30 PM
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 is starting off with a positive reputation.
check for cracks in the ic boots, stuck turbo veins etc on top of that. with it being loud at idle that could be less insulation in the engine compartment or sticky spool valves as well. i would start with the ic boots first and clean the egr valve and see where that leaves you. with a search you should be able to find a few writeup on egr removal and cleaning.
__________________
2004, f250, ccswb, 4x4, 6.0, psd, lariat, electric tcase, isspro boost/egt/trans, sct x2 w/spartan tunes, 315/75/r16 bfg km stock rims no lift
pretty much stock
  #8 (permalink)
Old 11-02-2009, 09:26 PM
jagski2 jagski2 is online now
jagski2 is starting off with a positive reputation.
I looked 5 years for the plug for the heater and could never find it. I found it wrapped up tight behind the bumper, pass side, right behind the tow hook. I bet I looked there 10 times before and never saw it.
  #9 (permalink)
Old 11-03-2009, 03:58 PM
jlmotox's Avatar
jlmotox jlmotox is offline
jlmotox is starting off with a positive reputation.
how can I tell if I have a block heater? where do I look?
__________________
2005 F250 FX4 4x4 PSD Lariet cc sb srw
Mbrp turbo back exhaust, Airaid intake w/zoodad mod, Banks PDA ottomind, Warn 12,000lb winch w/hide a winch bumper, BFG AT's, Pioneer Navigation w/ XM, reverse camera, 10" JL audio sub, 15% tint, reverse lights (aka A-hole lights)
  #10 (permalink)
Old 11-03-2009, 06:12 PM
PowerStrokeJoe PowerStrokeJoe is offline
PowerStrokeJoe is starting off with a positive reputation.
I have an 03 and it does have the block heater but like the others have said it is really burried. I had to follow the the cord out of the element in the block to find it. The plug is located just inside the right frame rail behind the fog light. My truck is bone stock and the only time it smokes is when I really let it have it and even then it is not much.
  #11 (permalink)
Old 11-04-2009, 11:03 PM
AndeyHall's Avatar
Problem Solved!!
Ok, so my prayers have been answered. I called a few friends that just know a good bit about diesels in general and told them about my issue, and they referred me to an amazing mechanic at our local Ford dealership. I took it up there to him and told him what was going on, he took a look under the hood, told me what my problem was but still wanted to drive it to make sure...he pulled out and opened up the throttle and sure enough, the smoke went EVERYWHERE! About a quarter mile up the road he pulled over, popped the hood, unplugged the EGR, and NO MORE SMOKE and no more loss of power. The throttle is so much more responsive now and no more bogging down at full throttle. I also had a pretty huge hole in the IC boot at the turbo, which was causing a loud blowing sound where the hood meets the windshield when the throttle was opened up, but I had never really thought anything of it before.
And yes, I had heard several times before that the factory intake on the 6.0 really had it together, and actually performs better than a CAI. The only reason I had not taken it off was because I bought the truck from an individual who had had the intake put on. It's not something I had done, because I do research and try and get all my facts together before I do any mods to my truck. I hate wasting money on useless mods. Does anyone know how much a stock intake costs from the dealership? The mechanic at the Ford dealership told me about a local diesel performance shop that would probably have several laying around from intakes they'd installed and would probably either trade me for my CAI or sell it to me for dirt cheap.
I also found the block heater on my truck. It was right where Egmonster's Diesel Tech Society site said it would be right between the fog light and the tow hook behind the bumper. I had tried looking there the other day but it's almost impossible to see back in there. I just reached back there and felt it and yanked the hell out of it until the zip ties broke loose (probably not the most recommended way but it worked out pretty well).
So the moral of the story is...keep your factory intakes, and get those EGRs the hell out of there. Preciate all of the help everbody.
Tags
black , f150 , faster , ford , quits , smoke , smokes , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
