Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 08:18 AM
rufko72 rufko72 is offline
rufko72 is starting off with a positive reputation.
tires 2006 f-150
I need to get a new set of tires looking fot some light truck tires . I am having a hard time finding the size tires that were installed at the factory. 255/70/17 in a LT tire . Can I go to a different size with out making a big difference. I am hauling a 5000 lb trailor would like something more stable then a P tire Thanks Rudy
  #2 (permalink)
Old 11-02-2009, 08:31 AM
f-150 on 22's f-150 on 22's is offline
f-150 on 22's is starting off with a positive reputation.
There should be a sticker in the door jam of your truck. Mine is on the driver side in between the driver door and the back driver side door.
__________________
2006 Lariat 5.4L 10" of total lift 8" Rize kit 2" AAL 2" Bilsteins , 20x10 Moto Metal 951 37inch Nitto Mud Grapplers Volant inakte with POWERCORE filter Edge Evolution Hornblasters Shocker S4 Trainhorn
  #3 (permalink)
Old 11-02-2009, 11:25 AM
Those are the tires that came on the truck that are on door panel .Having hard time finding LT tires in that size . Thanks Rudy
  #4 (permalink)
Old 11-02-2009, 02:39 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 is starting off with a positive reputation.
If you go to Tire Rack and enter your size, you'll get a list of tires. You can then select the tires you like, and click on specs, and see all the sizes and specs.
There are 14 tires listed, open up specs, like for example ... General Grabber AT2, available in 255/70-17, 640 AB UTOG rating, load rated 112S at 2469 lbs. at 44psi, 6.5-8.5 rim width, 10.2 section on a 7.5 rim, 31.1" diameter.
Down below in the chart is the same tire, size 265/70-17, 640 AB UTOG rating, load rated 115S, 2679 lbs. at 44 psi, rim 7-8", section 10.7 on a 8" wheel, just 31.7" diameter.
In 17" tires, about as high as it gets until you go for the heavy duty tires that need like 80 psi and will be hard as rocks on a F150.
I haven't seen many tires with LT designation in last few years. Now they are either Passenger .... or light truck / SUV tires, which get broken down into ... on road summer ... on road winter ... off road / all terrain ... and off road ... it seems.
Not recommending the Generals, just used for example. I have no experience with them.
Link 1
Link 2
  #5 (permalink)
Old 11-04-2009, 12:50 PM
18wheelin 18wheelin is offline
18wheelin is starting off with a positive reputation.
I have General Grabber LT245/70R17s on my truck. I have an 08 F150 XL with the heavy duty payload package. Tires come stock on the truck. I only have 5000 miles on the tires, so I can't tell you how they are going to wear, but they ride nice. I just wish they had a little more of an aggressive tread pattern for the WI winters.
  #6 (permalink)
Old 11-04-2009, 01:15 PM
week0019 week0019 is offline
week0019 is starting off with a positive reputation.
I have the same size and went with Bridgestone Duler AT Revo 2. So far so good but I probably only have about 1,500 miles on them.
http://www.ford-trucks.com/forums/88...dar-a-t-s.html
  #7 (permalink)
Old 11-04-2009, 09:07 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
Check out Tire Rack's site. They give all the specs on the tires they sell and have reviews and comparison ratings as well. You'll need to go up one size for a good LT tire selection. General does make an LT tire in 265/70x17 that is rated very well by Tire Rack as well as Consumer Reports. I'm probably going to get a set next year mostly based on these ratings and the fact that they have low rolling resistance for better fuel economy. I can't complain much about the General Americraps that came on my truck originally, but I know there are better tires out there for the money. They weren't real bad towing my 7000 lb enclosed trailer, but E rated would be better for towing. Even D rated on an F150 would be better. I can probably get 55000 miles out of those Americraps, but 40000 is enough for me.
  #8 (permalink)
Old 11-07-2009, 02:06 PM
marobrown marobrown is offline
marobrown is starting off with a positive reputation.
I have the Dayton Timberline AT 2, load range C. I bought them last year in March and have about 35000 on them so far. I went up to a 265/75/17, and found more choices in that size, went with these due to a friend working at the tire shop got them to me for 136/tire, when the orig. price should have been 186 each. When I got them they had 16/32 tread depth, now I am showing 11/32 on them so they seem to be wearing well, I rotate them every other oil change. I had load range E tires on my old truck and it rode like a shateboard after that, I have hauled my 3500# popup down to texas twice now and have not had any issues, also put about 2500 miles on hauling my buddies 26' travel trailer.
  #9 (permalink)
Old 11-12-2009, 12:23 AM
lv2race's Avatar
lv2race lv2race is offline
lv2race is starting off with a positive reputation.
I bought a brand new set of Michelins with the aluminum rims for $450 from a 2009 on Craigslist. Many people buy new trucks, upgrade the tires and rims and have a set of new tires waiting for YOU! Check it out if you are staying with the same size tire.
__________________
J Lowe
'90 F-150, 4.9 SOLD
'00 Expo, Triton 5.4
'06 F-150 STX, 4.6
Tags
2004 , 2005 , 2006 , f150 , fit , size , terrain , tire , tires , upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
