Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 08:08 AM
O's Fan Rich O's Fan Rich is offline
O's Fan Rich is starting off with a positive reputation.
Pulling a 4X4 trans.... Tips?
Ok.... time to get into replacing the front pump seal.
I have swapped/drooped quite a few transmissions in my years of DIY wrenching, but never did a 4x4.
1997 F250HD 5.8 extended cab.
Anyone have some tips or secrets to share?
Am I even posting in the correct forum for this?
  #2 (permalink)
Old 11-02-2009, 10:58 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 is starting off with a positive reputation.
Take the transfer case off first.
  #3 (permalink)
Old 11-02-2009, 12:55 PM
andym's Avatar
andym andym is offline
1989 Ford F-150
My Garage
andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future
Quote:
That's probably the best advice right there. No matter how hard you try, you will never get the transmission to bolt back up with the transfer case attached.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #4 (permalink)
Old 11-02-2009, 02:38 PM
Thanks Guy's.
Looks to me like it's a very straight forward operation.
  #5 (permalink)
Old 11-02-2009, 04:15 PM
rla2005's Avatar
You indicated you have pulled transmissions before, so you know the basics. The transfer case is a few more bolts, connectors. No big deal. The aluminum cased BW1356 is relatively light compared to the old iron case NP205 I had on my old '78 F-150. It was a man killer to move on your own. Take your time, make notes...very straight forward job.
  #6 (permalink)
Old 11-02-2009, 06:11 PM
rla2005's Avatar
You might find this helpful too: E4OD Removal/Installation
  #7 (permalink)
Old 11-02-2009, 07:28 PM
nat13_3 nat13_3 is online now
1995 Ford F-150
nat13_3 is starting off with a positive reputation.
When we took my M5R2 off of the junker the hardest part was breaking the seal in between the tranfer case and the trans. Other than that all it took was two ratchet straps, a nice socket set and some penetrant.
__________________
-Nathan
1995 F-150 351W 9" of lift ridin' on 37's locked but far from loaded...
http://www.youtube.com/user/natescamp
  #8 (permalink)
Old 11-03-2009, 02:44 AM
kdy72601's Avatar
kdy72601 kdy72601 is offline
1992 Ford F-250
kdy72601 is starting off with a positive reputation.
unbolt t-case, if you have a engine hoist pull the carpet and pull tranny hump pan coulple good rachet straps wrap them around the tranny one toward the front one towards the back put the enigine hoist in though the pass door put the rachet straps thought the hook on the engine hoist un-bolt tranny slow let tranny down with engine hoist helps if you have someone to balance the tranny under truck to balance it. had my tranny out front seal changed and back in, in a hour and a half
__________________
1992 F-250 XLT 4X4 X-cab long box 7.5L 460 CID, E4OD, BW1356, dana 50 , ford 10.25 4.11 posi, K&N, Taylor wires, flowmaster super 40, pro comp 1079 interco trxus m/t.
  #9 (permalink)
Old 11-04-2009, 04:36 PM
Quote:
I do. And to make things better, I'm going to pull the interior out to clean it up thoroughly anyway!
I appreciate all the help, Guy's.
  #10 (permalink)
Old 11-07-2009, 10:54 AM
I have yet to pull the trans out yet.
But, It did not take long to get the interior stripped out, less than an hour.
Removing that cover plate on the trans hump really provides easy acces to the upper bolts and will be a huge help.
Thanks again.
  #11 (permalink)
Old 11-07-2009, 11:15 AM
91nitemonster's Avatar
91nitemonster 91nitemonster is offline
1991 Ford F-150
91nitemonster is starting off with a positive reputation.
something that ive also learned over the years is that its alot easier getting to all the bolts that hold the tranny in by getting as many extensions u can, preferably enough so that your ratchet is behind the the tranny....then u can just lay/sit back there and see every bolt.....u may already know this but i used to try to get to them by laying right under the bellhousing and that makes the job twice as hard as it should be
  #12 (permalink)
Old 11-08-2009, 10:18 PM
Chevy 6.2D Chevy 6.2D is offline
1991 Ford F-150
My Garage
Chevy 6.2D is starting off with a positive reputation.
If you have a tranny jack, pulling the transfer case is a waste of time, IMO.
I switched the transmission in my '91 F150 and found it much easier to pull the trans/tcase out still together and pull apart on the shop floor. I reinstalled the same way.
Back on the road in 2 days- 1 to pull old trans, 1 to bolt tcase on new trans and put everything back in
I forgot to mention it sat for 3 weeks before I started working on it
__________________
'91 F150 x-cab XL 300 six M5OD 4x4 3.08 with LS
6 in a Row Makes It Go!
'88 F250 x-cab 7.3 IDI 5spd 4x4 3.55s
'95 F150 (SOLD)
NEW '79 Chevy crew cab dually
  #13 (permalink)
Old 11-09-2009, 01:42 AM
gijoe4500 gijoe4500 is offline
gijoe4500 is starting off with a positive reputation.
I just swapped a trans into my truck. Took lots of pictures. Its pretty straightfoward. Here ya go.
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
  #14 (permalink)
Old 11-09-2009, 02:22 PM
tecgod13 tecgod13 is offline
tecgod13 is starting off with a positive reputation.
Also can help to drain the tranny and transfer case first, this is especially useful if they aren't fully sealed (for a slip yoke or open between tranny and transfer case).
I found this out the hard way dropping an E4OD/transfer case this summer, made a giant spill all over...
Also watch out for a leak inbetween when you separate them, put a pan underneath to catch any drips.
Tags
1991 , 4x4 , betweenn , bronco , ford , leak , motor , pulling , tips , trans , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
