Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 12:59 AM
mweeps mweeps is offline
mweeps is starting off with a positive reputation.
Question Not shifting and now horn not working.
My Bronco is starting to go downhill quickly. First the rear spring perch rusted out and the spring is pushing up against the floor. Now is started shifting hard then the thing wouldn't shift out of second can't get above 30mph and horn quit working? 96 with 5.8 any place to start? I moved to Virginia and the Bronco is stuck 7 hours away in West Virginia. I would like to get it ready to bring over here.
__________________
96 Bronco XLT Sport
  #2 (permalink)
Old 11-02-2009, 05:20 AM
b4hntn b4hntn is offline
b4hntn is starting off with a positive reputation.
Have you checked the transmission fluid? The E4OD is sensitive to fluid level. Is it brown or smell burned? Drop the pan, replace filter, drain torque converter also. It should hold around 16 qts.
Find a big empty parking lot and drive in circles. Hold the horn button and turn the wheel to every possible position to see if it honks. If it honks you need a new clock spring.
__________________
If your ignition control module is a black Motorcraft (CCD system) do not replace it with a gray one (Push Start system). The wiring harness is different.
FTE is great! Be a supporter to keep this forum going. 94 5.8 EB, towing package, K & N drop in, MSD Blaster, 9 mm Ford Racing Wires, mechanical oil and temp guages and the rest all stock.
Tags
ford , shifting , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
