Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 11:44 PM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
Upper intake help
I'm working on my grandfathers 90 F-150 with a 302. I am trying to get the upper intake off but cannot figure out how I am going to get that center bolt out. It appears to be a torx screw, possibly a T-40, is there a special tool to get at this? I have a 3/8 drive torx socket but the base is too wide to fit between the intake to reach the bolt. A 1/4 drive might work but I have not seen one in that size. Any ideas?
__________________
"Tyranny is defined as that which is legal for the government but illegal for the citizenry." - Thomas Jefferson
  #2 (permalink)
Old 11-02-2009, 12:13 AM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 is gaining momentum as a positive member of FTE.
This question just came up a day or so ago. I know its a torx, and think its a T-40 or T-45. You need a long extension and you can access it through the center of the intake, there is a slit in it. Its not really noticable, but if you look for it you'll see it.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
  #3 (permalink)
Old 11-02-2009, 12:19 AM
lmd91343's Avatar
lmd91343 lmd91343 is offline
lmd91343 is starting off with a positive reputation.
I used a 1/4" drive with an 18"" extension, 1/4" socket, and a torx bit secured with electric tape. It may have been a T40 bit, I don't remember.
Remove the vacuum hoses from the tree first and also the PCV hose on the back. I don't remember the torque values for re-installation. I can check the Ford service manual if you need.
Remember to get a new gasket to go between the two intake halves.
__________________
-Lance
1989 f150 302 Lariat
MAF conversion; MSD 6a; MSD Blaster 2 coil; 3G alternator
insulated 460 intake tube; sound proofing; 3rd brake light
custom leather bucket seats; reupholstered door panels;
tach install; "A" pillar gauges
  #4 (permalink)
Old 11-02-2009, 12:20 AM
Boss_358's Avatar
Quote:
I see the cut in the intake, I just haven't found a torx that will reach. If someone makes a T-40 torx in 1/4, that might work. But the 3/8 drive I have will not fit due to the base being to wide. The 3/8 extension does fit though. Just not the bit itself. Now a bit with a long torx end on it would work.
__________________
  #5 (permalink)
Old 11-02-2009, 12:23 AM
Old93junk's Avatar
Old93junk Old93junk is online now
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Its a T-45 torx, there is another thread about this same thing here today, it will explain everything you need to know.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #6 (permalink)
Old 11-02-2009, 12:24 AM
Try putting the exension through and then attach the socket (torx) to it from the bottom.
__________________
1965 Mustang 302 T5
  #7 (permalink)
Old 11-02-2009, 12:25 AM
Boss_358's Avatar
That's what I am looking for, I just need to find a 1/4" drive bit.
I already have half of the upper part of the engine tore apart. I am doing head gaskets on the truck. I have the gasket set already. Luckily out of all the trucks I own, the 1980-96 manual covers most of them, so I have the specs. The upper intake is the only thing holding me up now. Besides that stupid EGR hose that is bolted to the rearmost exhaust manifold bolt that refuses to let go.
__________________
  #8 (permalink)
Old 11-02-2009, 12:26 AM
Boss_358's Avatar
Tried that, the bit is a little to tall for that to work. I'm gonna see if I can dig up that other thread.
__________________
  #9 (permalink)
Old 11-02-2009, 12:29 AM
Old93junk's Avatar
Old and mean
1993 Ford F-250
Its on the 2nd page now, .........."removing upper intake"
__________________
Dave
  #10 (permalink)
Old 11-02-2009, 12:32 AM
I remember when I took mine off to replace the injectors, I used one of the L shaped torx wrenches like the allen ones. It was a real PITA, but I got it.
__________________
1965 Mustang 302 T5
  #11 (permalink)
Old 11-02-2009, 12:33 AM
Boss_358's Avatar
Ok, I found it. if I would have gone just a little further I would have seen it earlier. Looks like I am not the only one with the problem right now. LOL. Now its time to see if I can dig up and old torx bit somewhere to use.
I even checked the Ford manual thinking they had some crazy special tool just designed for this purpose, but nothing. It seems they have tools for everything else.
Oh yeah, thanks guys for your help.
__________________
  #12 (permalink)
Old 11-07-2009, 02:58 AM
SFaulken SFaulken is offline
SFaulken is starting off with a positive reputation.
Ford might not have a special one, but Snap-On does.... I've got one.
Not cheap.
  #13 (permalink)
Old 11-07-2009, 11:23 AM
91nitemonster's Avatar
91nitemonster 91nitemonster is offline
1991 Ford F-150
91nitemonster is starting off with a positive reputation.
ive gotta a 5.8l so im not sure if there the same, but i got a 3/8 drive to ft in there....there should be a square shape cut out of the bottom of that slit, just big enough for a 3/8 drive to fit into.... it took some twisting, and precision but i got one in there....but then again i would have prefered a 1/4 drive
  #14 (permalink)
Old 11-09-2009, 02:32 AM
Boss_358's Avatar
I found not the set pictured, but something pretty similar to it at northern. It was the same price though. It worked very well.
Performance Tool Star Bit Drivers — 15-Pc. Set, Model# W1314 | Star Keys, Bits + Drivers | Northern Tool + Equipment
__________________
  #15 (permalink)
Old 11-09-2009, 02:35 AM
Boss_358's Avatar
I found not this exact set, but something kind of similar at northern. Price was the same and beat the hell out of making something to work. Oh yeah, and its a T40 bit.
__________________
Tags
ford , intake , tool , torx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
