Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 11:32 PM
500TPmech 500TPmech is offline
500TPmech is starting off with a positive reputation.
Anti freeze/coolant on my spark plugs
Any one know if the intake manifold can leak coolant and get it into the spark plugs holes. Started getting some missing today and pulled my left/driver's side plugs cause the OBD said missfire on #5. When I pulled the boots up off the spark plugs, there was coolant, I think it was coolant, half way up the spark plugs, just left side. Is there a coolant galley going along the intake manifold where the gasket could be leaking? My coolant level is not really low and the truck is not running hot. No noticeable change recently. Replaced the spark plugs couple weeks ago. It has rained here for three days straight and I washed the truck but never had this before. It sure had a slight smell of coolant. 1997 F150 4.6 litre W code. Thanks for any help !
  #2 (permalink)
Old 11-02-2009, 12:16 AM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
I know for the 5.4's that a coolant leak occurs at the rear of the intake which leaks into the sparkplug holes causing the cops to arc out and cause a misfire. might be the same thing here.
__________________
2002 F-150 Screw
Kenwood DDX512, Pioneer Doors, Image Dynamic Subs
Dumped Flowmaster Super 40
Trans-Go Shift Kit
Gotts Intake Mod
Tags
anti , antifreeze , drivers , f150 , fluid , ford , freeze , plug , plugs , put , radiator , side , smell , spark , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
