Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 11:13 PM
BP22's Avatar
BP22 BP22 is offline
BP22 is starting off with a positive reputation.
Lifted Our Excursion
Thanks to YellowSled for the great write up - http://www.ford-trucks.com/forums/86...ims-tires.html
Before:
37 inches to the middle of the front wheel well, 39 in the rear.
The job took two of us 6.5 hours using two floor jacks, two 12 ton jackstands and an air impact.
Took the wheels off and removed the front shocks. To get the front springs off you have to remove the bumper.
ProComp 22210 spring. I used Bilstein 5100s for the shocks.
My 1 1/2 year old son helping us get the spring in place.
In the rear I used a tapered 2" block under the stock block. I have Bilsteins for the rear, but did not have the shock bar pin so I kept the stockers on for now.
After:
41 inches to the middle of the front wheel well, 41 in the rear. This is with worn out 265 BFGs.
New tires are going on this week. Either 295 or 315 BFG ATs, I haven't decide yet.
  #2 (permalink)
Old 11-02-2009, 01:24 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
Nice!
Looks awesome!
If it were me I'd go with 305s, 295s are a hard tire size to find. 305s would fit well and are still available in load range "E". They also fit the stock rims well...
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #3 (permalink)
Old 11-02-2009, 05:14 AM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
2001 Ford Excursion
CanadianSmokie is gaining momentum as a positive member of FTE.
You should also look at replacing the stacked blocks in the rear with a single 4" tapered.
Safety for the little guy....
__________________
Ken
Ratt X
2001 7point3 PSD
All Go...No Show
  #4 (permalink)
Old 11-02-2009, 06:40 AM
ford12508 ford12508 is online now
ford12508 is starting off with a positive reputation.
You should look at replacing the stacked blocks in general, get some more leafs or something.
__________________
Brian
1999 Ford Expy 5.4L
Pioneer 4-way speakers, Ignition Ding turned off, Rubberized undercoating in process
  #5 (permalink)
Old 11-02-2009, 07:01 AM
YellowSled's Avatar
YellowSled YellowSled is offline
2002 Ford Excursion
YellowSled is gaining momentum as a positive member of FTE.
Looks great! Glad i can help. I agree with the block suggestions. I swapped out with one tapered block after the fact.
__________________
2002 Excursion Limited 4x4 V10 - Small ProComp lift on 35's (The family hauler)
2000 Excursion Limited 4x4 V10 - Stock w/37k miles
2006 300c SRT-8, The daily driver
2007 Charger SRT-8, The weekend car (12.7 1/4 mile, few mods)
2000 Volvo S70 5speed
  #6 (permalink)
Old 11-02-2009, 09:44 AM
BP22's Avatar
Quote:
Originally Posted by Toreador_Diesel View Post
Nice!
Looks awesome!
Thanks.
I looked at the 305s but I am concerned with the width and rubbing on the springs during a full turn.
__________________
Brandon ~SoCal
2004 Excursion Limited PSD 4wd: 4" Lift, Bilstein 5100, 295 BFG AT, Banks Monster, 94k miles.
1991 Toyota Land Cruiser FJ80: 31" BFG AT, 225k miles, stock & running strong.
2006 Correct Craft Super Air Nautique 210
  #7 (permalink)
Old 11-02-2009, 09:47 AM
BP22's Avatar
Thanks. Once I get the new tires on I will figure out what size block I need.
__________________
Brandon ~SoCal
  #8 (permalink)
Old 11-02-2009, 09:48 AM
BP22's Avatar
Quote:
Thanks again for all the great info you supplied.
__________________
Brandon ~SoCal
  #9 (permalink)
Old 11-02-2009, 10:17 AM
wely's Avatar
wely wely is offline
2000 Ford Excursion
wely is starting off with a positive reputation.
Great job on the lift. I can't wait to see it with the tires.
  #10 (permalink)
Old 11-02-2009, 11:07 AM
Jeepincj7's Avatar
Jeepincj7 Jeepincj7 is offline
Jeepincj7 is starting off with a positive reputation.
Stacked blocks are a big no-no. I would strongly suggest getting full springs for the rear or at a bare minimum the 4" blocks. You've got a family to worry about.
Otherwise, the X looks great.
__________________
Scotty
00' XLT 4x4, V10, 4.30s, 285s.
00' X, V10, 4wd, Ltd, 4.30s, 7" Donahoe Edge lift, 37" Toyo M/Ts on 17x9 Mazzi Hulks, Derale deep pan, A/T temp Gauge. (SOLD)
  #11 (permalink)
Old 11-02-2009, 12:17 PM
VaSheriff VaSheriff is offline
VaSheriff has a good reputation on FTE. VaSheriff has a good reputation on FTE.
Quote:
Originally Posted by BP22 View Post
My 1 1/2 year old son helping us get the spring in place.....
I would say I'm sorry for saying this, but I'm not. If you lived closer to me I would take an aluminum baseball bat
and knock you into Unconsious Land. While the image is adorable, accidents happen in a split second.
OK, got that off my mind! Truck looks good.... after you get larger tires mounted!
__________________
SQUIRRELS -- nature's little speedbumps!
  #12 (permalink)
Old 11-02-2009, 12:21 PM
BP22's Avatar
Thanks for the concern Sheriff. The picture is a bit deceiving by the angle it was taken. What you can't see are the two 12 ton jack stands holding the truck up along with the two floor jacks.
__________________
Brandon ~SoCal
  #13 (permalink)
Old 11-02-2009, 12:27 PM
OK!
Just don't want to see the little guy hurt!
__________________
  #14 (permalink)
Old 11-02-2009, 12:29 PM
BP22's Avatar
OK!
I knew you were sincere.
__________________
Brandon ~SoCal
  #15 (permalink)
Old 11-02-2009, 07:24 PM
dvldog458's Avatar
dvldog458 dvldog458 is offline
dvldog458 is starting off with a positive reputation.
Looks awesome bro!
__________________
2004 Excursion Limited 4x4 w/ 6.0L SCT X3 (Elite Diesel) ARP head studs, EGR Delete kit
8" BDS w/ 37" Nitto Mud Grapplers, MBRP 409 Turbo back
NJ Chapter
SEMPER FI
Tags
22210 , excursion , ford , forum , lifted , procomp , spring , springs , texas , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
