Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 11:02 PM
aroulette aroulette is offline
aroulette is starting off with a positive reputation.
Cranking issue
Ok, My problem first arrived by my turning the key and it cranking. Then I turned the key bank and low and behold it was trying to start on its own in the off position. I took the key out......the starter is still trying to start truck. Ran battery down and starter was fried so i replaced it. Got everythign hooked back up and I go to start and glow plugs light but when its time for the starter to kick in I get nothing, like before i replaced the starter.
A little history, about 7 months ago I pulled up to a buddies shop and went to turn ignition off and truck kept running. Took key out and it kept running. My buddy came out and messed with something by the steering column and it turned off and worked fine. Could it be the same problem? Belive he said he pushed something in. What is it and what do I do to try it?
  #2 (permalink)
Old 11-02-2009, 12:07 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
The ignition switch, the electrical part is on top of the steering column under the dash.
There is a pot metal rod that runs down from the key switch to the ignition switch to operate it.
And it is rather common for that pot metal rod to break.
What year is your truck and do you have a tilt wheel?
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 11-02-2009, 08:25 AM
I do not have a tilt wheel
I have an 84 F250 4x4 single cab
  #4 (permalink)
Old 11-02-2009, 08:26 AM
Also, if it broke, how do I fix it?
  #5 (permalink)
Old 11-02-2009, 09:10 AM
99SevenPoint3's Avatar
99SevenPoint3 99SevenPoint3 is offline
99SevenPoint3 is starting off with a positive reputation.
ignition switches can be purchased at many parts stores if im not mistaken they are under $20 dollars...
__________________
Zeus
_Early 99 7.3L 6spd F350 Dually 8" inch lift w/22.5's ..hpx,ccv,intank, zoodad -H/M k&n kit,SouthBendClutch, 02 turbo/w WW,intank pump club,Bellowed up-pipes,MKO 5" exhaust
_94 7.3L IDI Factory turbo 5spd F350 (some upgrades)
  #6 (permalink)
Old 11-02-2009, 09:45 AM
Is it easy to replace?
  #7 (permalink)
Old 11-02-2009, 11:40 AM
Lazy K Lazy K is online now
Lazy K is gaining momentum as a positive member of FTE.
The ign/start switch should be, as Dave S says, bolted to the steering column under the dash. It is held on by two bolts and connected back to the key switch by a rod and the ign switch actuator.
To remove the ign/start switch you may have to drop the column a couple of inches.
  #8 (permalink)
Old 11-02-2009, 11:43 AM
I believe I found the problem. I have no power across the solenoid. I'll try replacing that because it started by going across it
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
