Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 10:56 PM
5-20 5-20 is offline
5-20 is starting off with a positive reputation.
Question Starting Problem.
I've being reading this forum for some time and have use this forum to find out what is wrong with my truck and fix it. Most of the times I just read through here and can find most of the problems. So this is a first for me to write about a problem on my truck to this forum. I have an F-350 7.3 automatic 4x4 here is my problem. The other day I was going to work and my truck all of a sudden lost power on the highway I was going around 65 mph and it went down to 35 mph luckily I was on a downhill coasted the truck to a stop and it was hesitating really bad. So I pulled over and it turned off on me. When I tried to turn it on again it would only crank and not start. It sounds good when cranking but won't start so I had it towed home. I check the harness and the harness under the value cover and one of the connecters was burned the passenger side value cover harness so I replaced the value cover gasket and modules along with all 8 glow plugs since I had the value covers off. Still won’t start so I change the CPS still only turns but won’t start. So I check the fuel housing and no fuel just very little and a lot of gunk. So I took out the housing and cleaned it out. I also found the screen to I believe is the fpr clog so I clean that as well. Still only cranks but won't start. What I'm thinking is it is the fuel pump. But before I spend a 100 dollars I would like to know if anybody have any ideas what it could be? I would hate to be spending money on parts and not fix my problem. fficeffice" />>>
  #2 (permalink)
Old 11-01-2009, 11:04 PM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Could you explain the "gunk" for us?
Could have algee in the fuel if its that kinda gunk. and might be in the lines or stuck on the pickup tube allowing no fuel in.
Did you pull the bowl when you cleaned it?
If so, did you pull the FPR off and clean that separately?
Be sure to watch out for the o-ring if you take it off.
The FPR piece comes out, just not very easy. took me a minute to wiggle it out.
I cleaned and blew the passages in the FPR out there also.
Those are my only idea's for you. Sounds like you got a decent handle on a lot of other things. If you could explain the gunk, and if the filter was black and slimy or what not, that will help a lot of more experienced guys be able to tell if you got algee problems.
I have not ever seen it, so I don't know what it looks like.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
Quote:
Originally Posted by Action4478
the columns aren't made out of marshmallows...Just wiggle it ....
  #3 (permalink)
Old 11-02-2009, 03:39 AM
Oversize's Avatar
Oversize Oversize is offline
1996 Ford F-250
Oversize is gaining momentum as a positive member of FTE.
It sounds to me like you did it right. In reference to Talyns question about the "GUNK" algae will look black and oily rather like tar only much thinner. If that what you had in your bowl It could easily be algae which can plug things up, Assuming thats what you found, you need some algacide or some real good quality injector cleaner or both. If it wasnt anything like that then its probably just your fuel pump took a dump on you. You could fill your entire filter housing with injector cleaner and start it for a quick clean, or just fill it back with diesel and run it, its possible but doubtful that restriction pullged it up so fast that it simply ran you out of prime unless something is retricting your intake pipe in which case you need additive in your tanks to clean out the algae. If it is algae you need to do that and change your fuel filter several times before it goes away completely. Usually you only get algae if you had some water in your fuel and especially if you left it sit for a long time with out running. Let us know.
__________________
96 F-250 HD, SC, LB, 7.3 DI Diesel, 5 spd, 6" lift, 35" AT's, 3" DP, cat gut, 6" straight pipe, 4.10's, FPR shim, custom intake, Hot pedal, HPX, Pyro, Boost, ...
Professional driver, Former CAT and Industrial Mech, P/T race engineer.
  #4 (permalink)
Old 11-02-2009, 01:51 PM
Yeah sorry I didn't explain "gunk" it was algae on the bottom of the housing also there was some white foamie stuff not a lot on top floating on the diesel. Also the fuel housing had very little diesel on it right underneath the heater. Thanks.
Tags
73 , di , diesel , problem , start , starter , truck , turns , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
