Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 09:32 PM
BULLETPROOF4.9's Avatar
BULLETPROOF4.9 BULLETPROOF4.9 is offline
BULLETPROOF4.9 is starting off with a positive reputation.
O2 sensor query
O.k., I have a 96 E.B. Bronco, I've removed the cats, and have dualed it out with glass packs down the passenger side. My question is, if I put the after cat o2 on one side of the exhaust, will it be enough of a difference to make the PCU think it still has a cat and keep it from throwing a CEL?
  #2 (permalink)
Old 11-01-2009, 10:06 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Without a cat the downstream O2 will not function properly, get an O2 eliminator to plug in instead.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 11-02-2009, 12:31 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar is starting off with a positive reputation.
O2 eliminators cannot be legally obtained in the US. Put a cat back on, you will produce more HP and torque with a properly functioning cat than without. With the glasspacks, it will be plenty loud. It you want it louder, eliminate the glasspacks and run just a cat.
  #4 (permalink)
Old 11-02-2009, 07:40 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
"MIL Eliminators" do NOT eliminate the downstream sensor. The OBDII system still requires an operational sensor to be installed in the exhaust stream.
The MIL "eliminlator" simply modifies the output of the downstream sensor so it mimics the output of a sensor that is downstream from a functioning catalytic converter.
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 11-14-2009, 07:09 PM
Ok, exhaust mods have been done, dual pipes down the passenger side into glasspacks, and turned out in front of rear wheel, with the o2 sensor installed in one side. No CEL, sounds good. Apparently with the o2 in just one side, cutting the down flow by half, tricks it into thinking it has a CAT. I didn't have the o2 installed properly before and had a constant CEL because of the lack of exhaust flow.
Tags
96 , eliminators , f150 , ford , o2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
