Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 09:31 PM
Erik727 Erik727 is offline
Erik727 is starting off with a positive reputation.
Alternator or battery (s) 2004 F-250 6.0 DSL
2004 F-250 6.0 DSL King Ranch...Driving home from the moto track with 3 bikes and a 4-wheeler in the trailer...First ABS light comes on..no biggie...10 min later ..all my instruments died ,tach, speedo,trans temp,eng temp,along with, radio ,windows..All of it inop....Turn sigs worked,but dim,,they died later...Truck continued to run good...Kept going to the house about 30 mins of highway..Pulled up in front of house ,went to hit horn ,,and that killed the motor. Never got a ck eng or batt light ,,only the ABS light on.
Truck wouldn't turn over,,just the click,click,click...Ck'd all applicable fuses,,all good. Hooked jumper cable up,,let charge for ten mis or so,,truck started right up,,everything working. ABS light remained on.
With truck running after jump start (jumper cables disconnected),,Got my meter and measured volts at each battery..Both said 12.2 volts...After about 10 mins ...same thing,,all instrumentation died ,, I shut truck off...Tried to restart ,,no dice...click,click,click..Ck'd volts at both batteries,,both read about 10.5 volts.
There's the story...The question..Shouldn't i be seeing 14volts at the batts with the truck running ? Shouldn't i have gotten the Batt idot light if the alternator wasn't putting out enough volts ? The batteries are Duralast Golds,,they are just under a year old. Alternator is origanal equip.
So,,do i have 1 or 2 bad batteries or a bad alternator ? Or something else ? What do you think ??
Thanks in advance
Erik
__________________
2004 F250 6.0 FX4 King Ranch
  #2 (permalink)
Old 11-01-2009, 10:00 PM
texans's Avatar
texans texans is offline
texans is gaining momentum as a positive member of FTE.
Bad alt. Truck should never die while running if the alt is good. You may have a bad battery now too since the alt is on it's way out. Get the alt tested and yes you should see somthing like 13.5 volts at idle. Be sure to replace both batteries if one shows to be bad. It's bad to replace one at a time on these trucks. One last thing get this fixed asap. Low voltage will kill your ficm and that isn't a cheap part. That is why I recomend replacing both batteries when one is bad. It a lot cheaper than a ficm.
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #3 (permalink)
Old 11-01-2009, 10:08 PM
Thanks,,that's what i figured as well. Next ?? Did the ABS light come on due to volts not high enough on sys ?? Or Coincidence...
__________________
  #4 (permalink)
Old 11-01-2009, 10:13 PM
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 is starting off with a positive reputation.
the alt swap is easy. if you had or have one bad battery it is easy to over work the alternator and melt the diodes. but definately sounds like the alt is down for the count
__________________
2004, f250, ccswb, 4x4, 6.0, psd, lariat, electric tcase, isspro boost/egt/trans, sct x2 w/spartan tunes, 315/75/r16 bfg km stock rims no lift
pretty much stock
  #5 (permalink)
Old 11-01-2009, 10:15 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Quote:
Very sound advice texans!
Erik727 - the ABS light is most likely related to the alternator problems.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #6 (permalink)
Old 11-01-2009, 10:21 PM
texans's Avatar
One thing that I have found with the abs too. Is that when it comes on it will not turn back off till you drive it. Found that out from wheel bearing problems i have been having fix the problem but the abs lights stays on till I drive a little then it goes off and stays off till have anouther problem. I would think that it is related to the alt in your case
__________________
Scotty
  #7 (permalink)
Old 11-01-2009, 10:27 PM
That's what i figured...Thanks for the help.. I've read all about the bad batteries and FICM problems,,that's why when i had a batt start going last year ,i changed them both..
Thanks again,,i will change alt tomorrow.
__________________
  #8 (permalink)
Old 11-01-2009, 10:30 PM
texans's Avatar
No problem let us know if you need any help (I don't mind drinking a beer and pointing out the tools
__________________
Scotty
  #9 (permalink)
Old 11-01-2009, 11:38 PM
pretty simple. use the kickstand on the tensioner bracket just below the alt keep the belt some what taught and it will be very easy. do a search and there are alot of pictures of exactly what im talking about. i use a claw hammer to get enough tension to lock the kick stand. then it is a 9/16 or 1/2 socket or wrench and a 10mm socket or wrench i believe.
__________________
pretty much stock
Tags
2001 , 2004 , 60 , abs , alternator , battery , change , changing , clicks , diesel , f250 , ford , light , problems , replace , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
