Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 09:25 PM
DAAJR DAAJR is offline
DAAJR is starting off with a positive reputation.
Help, vibration after install
Ok my tranny went out, metal shavings and bearings in the pan.
E4OD 4x2 94 f150
I am on a tight budget so I found a used tranny and decided to install myself.
I used my old tourque converter and the used tranny.
We took it for a test drive a I have a very bad vibration when in gear
and stopped, like at a stop sign. If I put it in park or neutral it goes away.
So...
Is the used tranny bad?
Was my TC damaged when my tranny went out and no good?
Did I install something wrong?
Did the Gods of fate decide something else should go wrong at the same time?
Please help, any ideas or suggestions are appreciated
thanks
Don
__________________
94 f150 supercab shortbed 4.9, 4x2, e40d, 3.55s, 31x10.5s
  #2 (permalink)
Old 11-01-2009, 10:52 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
You used your old TC? You take it apart and clean all the metal etc that was in it out? The same stuff that was in the pan?
As for the vibration, could be the TC, could be a bent flex plate damaged in the install, could be the trans.
  #3 (permalink)
Old 11-01-2009, 11:27 PM
icrman icrman is offline
icrman is starting off with a positive reputation.
Just like the other guy said.
Did you ever think that the whole cause of the metal in your first transmission was because the torque converter crapped out? Maybe and maybe not, but just a heads up.
That was a huge mistake, if you had metal in the pan then you need to clean the oil cooler and the torque converter, if you don't your just ruining what ever else you install into your truck, new, used or rebuilt transmission.
__________________
1996 F-250, XLT 460 E4OD, Long box, Supercab 4X4, 4.10 Axle Ratio, Camper and tow package.
Self install of: Clifford alarm, B&W Flipover gooseneck hitch, Ride Rite airbags, and compressor system, Prodigy Brake controller.
  #4 (permalink)
Old 11-02-2009, 09:18 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Any crap that was in the old tc, lines & cooler would go right back in the new trans when the engine was started up.
__________________
'79 F250 13" lift 42" Super Swampers
  #5 (permalink)
Old 11-02-2009, 09:41 PM
When the old tranny died I drained the whole system, pan, TC and Lines
Dropped the pan to put in new filter and found the metal.
I assumed (We all know what that means) the filter would have kept debris
from the rest of the system.
Can you take a TC apart to clean? Looks like it is sealed.
Is there any way to test TC to see if it is the problem?
Where do I get a new flex plate?
Do they need to be ballanced?
Is it just a ford dealer part?
Is there any way to test which part is the problem, flex plate, TC, trans?
Thanks
Don
__________________
Tags
clutch , e4od , engine , install , vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
