do you all think seafoam will eat return lines?im thinkiing about dumping a whole can in my tank to really clean the injectors because of the stinkin' intermittent knock i have developed.because i really dont have the cash for new injectors right now
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
i use a full can in the fuel filter every time I change the oil without any problems, I say go for it
__________________ 1984 f250 6.9 idi diesel 4x4 with a borg warner t19 4 speed manual with a granny gear, 7.5" western unimount plow... ROLLIN' COAL!
'96 F350 crew cab XLT dually 2wd alcoa wheels 7.3 PSD E4OD ,300,000 miles+
64,999,987 firearms owners killed noone yesterday. protect our second amendment
hmm maybe 2 cans in the tank then?i just dont want to buy new injectors right now and the knock makes me go nuts and makes me cringe
__________________
i would say pour one can into ur fuel filter do as everyone does crank it up for a min then shut it off and pour the other can into ur fuel tanks 50/50 ...then start the truck back up and go for a drive
hey rupe, something to maybe look at is the sulfur additive. i use it every few tanks and so far no problems. dunno now many benefits it has, but it cant hurt.
__________________
87 6.9 3.55 T-19 thats about all i know about it
The sulfur would be a help, the ultra low sulfur diesel doesnt lube the fuel system as well as the diesel we used to have, so if you use it per the directions it would give your fuel system the lube it was intended to have.
