sounds like the lift pump might be getting worn out.
how many miles on the engine,and has the mechanical lift pump ever been changed?
(fuel pump bolted to engine under the fuel filter)
these luckily are only 40 bucks or so.
vacuum test the fuel pump.
remove the fuel line from the pump that goes back to the tank and plug it so nothing gets in.
hook a short tube to the pump with a vacuum gauge on it.
start the motor and read your gauge.
if you have less than 12 inches HG then you need a new pump.
don't worry,these are only $40 or so.unlike the ip pump.
if you dont have a vacuum gauge,you can just remove the line that goes to the filter and see if it pumps into a bucket with good flow.not the best way,but if its real bad,and hardly flowing,you would know for sure that she's tired.
but be sure to check for leaks on both sides of the line connected to the lift pump first.dont get hurt around that fan!!!!
if it does test bad.now is a good time to bring the fuel system up to speed a little bit.research electric fuel pump conversion.
switching to electric would eliminate a lot of hard starting problems.the electric pump would push,not suck,from the tanks(well very close to them)up to the fuel filter.this means,air leaks from tanks to fuel filter are no more problem-ever!
and free up a small amount of power as well.all extra power is good.
