Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 08:55 PM
JHoffman93's Avatar
JHoffman93 JHoffman93 is offline
JHoffman93 is starting off with a positive reputation.
SSDiesel glowplugs
Has anyone heard of or used instant-heat gps from SSDiesel Supply? They claim that they don't swell, the pictures look impressive. They also claim that they supply the military with thier gps.
__________________
Aircraft Mechanic, Wichita Citation Service Center. Proudly burning B100 from Healy BioDiesel in my 2001 VW TDI and 1993 F250 Ext. cab IDI with a 5 spd manual trany 2x4.
  #2 (permalink)
Old 11-01-2009, 09:50 PM
JHoffman93's Avatar
I have been doing some research. It looks like SSDiesel is selling gps made by WAP Inc. out of Indiana. They are a dual coil plug made here in the US. They make gps for tractors, big rigs and many other diesel engines. I wish I could find someone that has used these plugs and what they thought of them.
__________________
  #3 (permalink)
Old 11-01-2009, 09:53 PM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh is starting off with a positive reputation.
wap is wellman which is currently what i have in my truck and they seem to be ok
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #4 (permalink)
Old 11-01-2009, 10:13 PM
JHoffman93's Avatar
How long have you had them in your truck? Are they the dual element instant heat plug or a single coil? I went to WAP's web sight and they look like a good comp. with good products. Hopefully some others will chim in here. I lost a bid on Ebay for a set of Motorcraft plugs by a dollar. They hadn't been bid on in seven days and in the last 10 min. someone out bid me by a dollar, boy was I mad, I could have had a set of 8 for 50 dollars.
__________________
  #5 (permalink)
Old 11-01-2009, 10:45 PM
jhnlennon's Avatar
jhnlennon jhnlennon is offline
jhnlennon is starting off with a positive reputation.
I have heard nothing but bad bout wellmans in the long run. Beru's or a 12 volt plug are the only way to go
__________________
1984 f250 4x4 6.9 4spd flatbed banks non gated turbo
  #6 (permalink)
Old 11-01-2009, 10:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
David85 had to pull a head to retrieve a Wellman glow plug tip.
I think he has a picture of the piston in his gallery.
450,000 miles, not one problem with Motorcraft/Beru glow plugs.
I think I will stay with the tried and true.
Just remember, if you have to pull a head or replace a piston, Motorcraft glow plugs would be a deal at 50 dollars each.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #7 (permalink)
Old 11-01-2009, 10:56 PM
Knox's Avatar
Knox Knox is offline
Knox is starting off with a positive reputation.
yeah but for the price of 8 at 50 bucks you could just get a whole new (used) truck
good thing you can get em for 10
  #8 (permalink)
Old 11-01-2009, 11:02 PM
David85's Avatar
David85 David85 is online now
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
My experience with WAP glowplugs was not good.
Ran 080s (the stock drop in replacement) for a while and eventually a manual switch left on too long caused ALL of them to loose their tips in the engine. That was the event that forced my to rebuild my engine. I got these in a mail order from MWFI thinking they would send me beru plugs.
I tested an 088 (this is supposed to be a dual coil) and it started swelling right around the 9 second mark. After 23 seconds it let out a little puff sound and the tip finally ruptured and power stopped flowing. By then it was about 5/16" thick which could not have been removed from an engine.
I did read a lot of good things about WAP plugs including that they were made in USA (generally a good thing!), used for military contracts, used in humvees that have to be idiot proof, and so on. In the end they did not live up to the reputation. Maybe I had a bad experience or maybe it was a bad batch during that era but let me tell you there needs to be a large loaded gun pointed to my head to ever install a set of wellman plugs again.
My advice to anyone that is thinking of trying a new brand or type of glow plugs is to test them to really see if they are self regulating as they claim.
I did manage to burn out a set of beru plugs in similar fashion as the 080s (thanks to a deffective controller) and they all stayed in tact and came out in tact. The difference is the tip will rupture at pinholes instead of stretching into a baloon.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #9 (permalink)
Old 11-01-2009, 11:50 PM
1986 Ford F-250
That is a 4500 dollar engine, and that is just parts and machine shop work not counting my labor, so no you will not buy that and a truck for 400 dollars.
When Autozone was selling off Motorcraft/Beru inventory I bought all they had in two stores for 1.99 each.
But if I needed to buy more tomorrow, I would not think twice about paying 50 dollars each.
I know exactly how long it takes to pull a head and reinstall it.
14 hours of hard wrenching for two people plus a return line kit, valley pan, head gasket and rocker cover gasket (200 dollars).
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #10 (permalink)
Old 11-02-2009, 07:50 AM
tjc transport's Avatar
tjc transport tjc transport is offline
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
7.3 Liter Diesel Motorcraft Glow Plugs - Ford 7.3 Liter Diesel Motorcraft Glow Plug
motocraft plugs for $9.99 each.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #11 (permalink)
Old 11-02-2009, 11:31 AM
timothyr timothyr is online now
timothyr is starting off with a positive reputation.
While we are on this topic (and because I am too lazy to go pull one right now), are the beru's (ZD-9) 6v or 12v?
Reason I ask is when I went to manual control I also replaced all of the wiring...each GP sees a solid 12v; I HAD 8 new beru's ZD-9's...3 are now dead - they lasted all of maybe 3 weeks, typically the longest duration on was 6~7 secs, longest was 12.
I read somewhere that the zd-9's were 6v, and if so i am thinking going to a good 12v plug may be more reliable
__________________
86 F350 Crew Cab Dually - 6.9l IDI w/a 4-spd
  #12 (permalink)
Old 11-02-2009, 12:01 PM
oh no, not again!!
your 86 6.9 should be using ZD-1 glow plugs, not the ZD-9's
__________________
Tom
  #13 (permalink)
Old 11-02-2009, 08:41 PM
JHoffman93's Avatar
Thanks for the feed back guys. Your experianced with the WAP
__________________
  #14 (permalink)
Old 11-02-2009, 09:12 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is starting off with a positive reputation.
My '86 uses ZD-9s but I think someone combined old and new GP systems.
Didn't function.
That's why it's manual control now.
__________________
'91.5 Dodge,4WD,Intercooled Cummins;5 Spd.,NP205;D70R,D60F,3:54s
'94 F350,4WD,CrewCab;7.3L IDI Turbo,ZF5;D60F-3:54 374K Straight-piped
'86 F350,2WD,CrewCab,6.9L NA,T19,10.25"4:11
'97 F350,4WD,460,E40D,D60F 3:54, 269K
'97 F250,PowerStroke,4wd,Xcb,E40D,3:55/54,284K Straight-piped
'95 F350,4wd,PowerStroke,CrewCab;D60F 4:10,ServiceTruck,300K,Straight-Piped
  #15 (permalink)
Old 11-02-2009, 09:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
based on my research,i will only be using motorcraft/beru brand glowplugs in my truck too.
there's not really any point to do anything else.
they last forever and a day if your hooked up properly,or know how to operate a manual plug.its doubtful all 8 are bad unless something is seriously wrong-in which case you would then test everything else before burning out 8 more anyway lol.
so for 10 bucks a pop,and what should go 200k-300k miles shoot.....you cant run spark plugs in a car that cheap hahaha.
dont be tight and try to save $ cus its gunna bite ya in the butt when it comes to swollen up plugs iv been reading.
some things you can save $ on.
glow plugs is just not one of these things.
(when you have a couple bad GP's,its not like a wear item,like a spark plug,and it means you should replace all 8.the others can go for another 100k miles! or more.just replace the bad ones guys)
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
Tags
99 , beru , coil , dual , element , f350 , ford , glow , glowplugs , gps , how , install , plugs , power , ssdiesel , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
