Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 11-02-2009, 11:08 PM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
For the record, I would still like to try any dual coil glow glow plug I can get my hands on, but I will do my best to kill it on a bench before it goes anywhere near my engine.
By fluke I was able to find a 10.8V plug for the diesel ranger and it concept does work well. Heat up times are about twice as long, but those can be left on steady while the engine is still warming up with no harm to the engine or the plugs. I haven't tried leaving them on all day while driving, but the point is they burn like a light bulb instead of burning out after 20 seconds.
From what I've read of the bosch duratherm dual coil plugs, their output is actually higher than a stock glow plug. So while the heat up time is longer, they still put out more heat once they do reach full power. However, this is only what I've read so until I test one, I will still hold back from recommending anything other than the german made BERU plugs even if they are not self regulating.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #17 (permalink)
Old 11-02-2009, 11:44 PM
Knox's Avatar
Knox Knox is offline
Knox is starting off with a positive reputation.
i cant figure out how to use the volt meter i have so is there any other way to find out what ones are bad and what ones are good?
(i was talking about S&*^Y trucks and motors like mine)
  #18 (permalink)
Old 11-03-2009, 02:07 PM
S.P. S.P. is offline
S.P. is starting off with a positive reputation.
Talking
Quote:
Originally Posted by Dave Sponaugle View Post
David85 had to pull a head to retrieve a Wellman glow plug tip.
I think he has a picture of the piston in his gallery.
450,000 miles, not one problem with Motorcraft/Beru glow plugs.
I think I will stay with the tried and true.
Just remember, if you have to pull a head or replace a piston, Motorcraft glow plugs would be a deal at 50 dollars each.
Thats all too true Dave.
__________________
"YOU'RE JUST JEALOUS THAT THE VOICES TALK TO ME"
1991 F250 X/cab, 4X4, 7.3l, w/ATS Turbo, Lariat, egt & psi gauges, 33" tires, and now with a 5th wheel hitch..
  #19 (permalink)
Old 11-03-2009, 04:19 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
yippy!!!
i tested my GP's today,and only found 1 bad.
replaced with a motorcraft/beru made in germany gp,and she starts WAY easier!(though its not real cold yet,she cold started in only a couple seconds.-was minutes before lol)
im a happy camper.
hey do you guys use never seize on your GP's when putting them in?
the old one sure turned out hard,so i put never seize on the threads.
this is a good idea right?
im almost on the road!
need a couple tires and getting my dump/flatbed this week (found a great deal!!) and then she will pass inspection.
yeah baby! can't wait to put this NOS (new old stock) '93 to work!
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #20 (permalink)
Old 11-03-2009, 10:47 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is starting off with a positive reputation.
I have always put anti-sieze on mine.
__________________
'91.5 Dodge,4WD,Intercooled Cummins;5 Spd.,NP205;D70R,D60F,3:54s
'94 F350,4WD,CrewCab;7.3L IDI Turbo,ZF5;D60F-3:54 374K Straight-piped
'86 F350,2WD,CrewCab,6.9L NA,T19,10.25"4:11
'97 F350,4WD,460,E40D,D60F 3:54, 269K
'97 F250,PowerStroke,4wd,Xcb,E40D,3:55/54,284K Straight-piped
'95 F350,4wd,PowerStroke,CrewCab;D60F 4:10,ServiceTruck,300K,Straight-Piped
  #21 (permalink)
Old 11-03-2009, 11:05 PM
symonds86's Avatar
symonds86 symonds86 is offline
symonds86 is starting off with a positive reputation.
i agree with ya 100% I bought a new set of motorcraft/ beru 40,000 miles. when the motor went i pulled them and gave em to my buddy who has a 94 idi and he is still using them.
  #22 (permalink)
Old 11-04-2009, 09:57 AM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
I put copper anti-sieze on all my GP's.
Thanks to various problems, mine has an all new set of ZD-9's as of this year...probably just as well, the rear cylinders on both sides of the truck had Champions in them (which is odd, since all the rest were original ZD-9's).
Truck starts a lot better now, too bad my GP controller is completely on the fritz, have to use a pushbutton.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs. 4" intake tube, ATS upgrade, 4" exhaust w/ Walker 21172, boost & pyro on pillar, Autodim mirror, 16x8 MB Razor wheels w/285/75R16 "MT-R's"
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
2008 V-Star 1100 Midnight Custom-Just Cobra slip-on drag pipes for now
  #23 (permalink)
Old 11-04-2009, 02:00 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
You really can't argue with experience, but there are those that make errors. Better to have something that is inherently safe. If BERU has a glow plug with dual coils to control temperature, I don't doubt that it would be a good one. If anyone has knowledge of such an item, I would be highly interested in getting some of them. In the mean time, I recommend the AC 12G or the Autolite 1109. I know these are temperature limiting and you can leave them on indefinitely with melting them down. You will kill your battery if your offspring accidently hits your switch and leaves them on. I can't help thinking that the bad impression people have of the OEM GPs comes from failed controllers that the engineers designed into the systems come with a Quick start system. I worked for AC Spark Plug in the lab that tested the GPs. I know of which I speak!
  #24 (permalink)
Old 11-04-2009, 05:31 PM
David85's Avatar
Quote:
I remember you mentioning those ones in another discussion on this topic. Tried to source them through NAPA and another autoparts retailer and neither could get it in. One of them showed something like 3 units in the system way the heck over in ontario. Don't understand why they would be so hard to find.
Autolite is a cussword over here because their drop in replacements are so bad for these engines, but if the dual coil works as claimed I would consider using them.
I remember you also advised to dry test every glow plug before installing it in the engine. That was something I hadn't hear before then, but it makes sense.
__________________
  #25 (permalink)
Old 11-04-2009, 07:52 PM
Sorry, I misstated myself. I meant to say that you can leave the AC 12G and the Autolite 1109 GPs on indefinitely WITHOUT melting them down. They are temperature limiting and will get red hot and stay that way as long as you have power on them. I bought a set of autolites for $10.00 a piece. Remember to heat each GP before you install it. That way if there is a problem, you won't have to fight with it to remove it. It will also prove that it is a temperature limiting type. Like I said before, cheap insurance and totally foolproof.
  #26 (permalink)
Old 11-05-2009, 09:31 PM
OK I think i've found the holy grail for GPs. The military HUMVEES use a 6.2 GM diesel and guess what! The GPs will fit the 6.9/7.3. The terminals may be different, but the threads are the same and although ones thread is longer than the others it does not matter. BERU makes a GP for these that are said to be non swelling and temperature controlled. They are pricey but when you're talking about $800.00 to pull the heads to remove swollen GPs. It's cheap insurance. For BERUs: https://www.real4wd.com/B1WebTools/c...spx?PartNo=007 $21.15
Check out this website: Glow Plug - Military Humvee 6.5L I've emailed them regarding their GP_65MILHUM GPs. They even have the correct terminal! $68.5 + S&H.
  #27 (permalink)
Old 11-05-2009, 09:43 PM
1993 Ford F-250
how can we figure out a way to make these ones work?
BERU offers 3-phase glow plugs of the GE and GN type.
what are these suckers made for,that use the same thread pattern as our idi's?
are these ones here,that you mention for $68 each the same as those basically?-oops.correction.thats $68 for a set of 8! coooooool.
http://www.accuratediesel.com/shop/115.html
splicing new connectors is easy enough.
this is good stuff!
__________________
  #28 (permalink)
Old 11-06-2009, 02:56 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
I just replaced 2 bad GP's with MC/Beru's. I was a bit dismayed to find I was removing autolites. If the price hadn't doubled($5.89 to $14.99) I would have done all 8. At least the autolites came out nice and easy, no swelling. I will buy new GP's as often as I can until they are all MC/beru's though.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #29 (permalink)
Old 11-06-2009, 07:36 AM
tjc transport's Avatar
tjc transport tjc transport is online now
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
but why would you pay $21.95 each for the wrong aftermarket glow plug when you can buy the oem plug for $9.99??
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #30 (permalink)
Old 11-06-2009, 11:08 AM
Sorry, I went off half cocked and told you that the GPs at "Glow Plug - Military Humvee 6.5L" were temoerature limiting. THEY ARE NOT TEMPERATURE LIMITING.
Tags
99 , beru , coil , dual , element , f350 , ford , glow , glowplugs , gps , how , install , plugs , power , ssdiesel , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
