Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 08:42 PM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is online now
rtcalabrojr is starting off with a positive reputation.
can i weld to my rear center section?
can i weld to the center section on my 8.8? I have bottom bag brackets that would go onto the axle but my center section is offset. I looked at it today and was wondering if i could just notch the bracket around the area needed and weld it to it. I thought they plug weld the axle tubes in the center section? So heres a pic!! The area im looking at is on the left side of the pic!
Photobucket
__________________
Roger
1955 F100
I smell cookies! click to check out the truck
http://s919.photobucket.com/albums/ad37/rtcalabrojr/
  #2 (permalink)
Old 11-01-2009, 09:41 PM
rbig1 rbig1 is offline
rbig1 is starting off with a positive reputation.
its cast iron it would never hold. even with cast iron rod would not have strength. its not a high grade of cast a lot of impurties
  #3 (permalink)
e-tek's Avatar
e-tek e-tek is offline
e-tek is starting off with a positive reputation.
As far as "can you weld to the centre-section", I'd say yes, of course. You can modify the mount and weld it where you need it.
The issue I have is more one of suspension dynamics. As long as it would not bind there, if side to side travel is still OK, then no worries. Just check those issues as you go.
  #4 (permalink)
Old 11-01-2009, 09:52 PM
e-tek's Avatar
Quote:
Actually you can - but it requires some special techniques: what you need is a stick of 1/4" plain gray iron rod, some borax flux and a torch. As well, you should preheat the part, then let it cool VERY slowly for best results.
Regardless - in looking at your photo - it would "appear" that you may have enough room to mount it on the axle - especially if you made a bracket that brought the bag mount over to where you wanted it. May save you the hassle of trying your hand at cast welding!
  #5 (permalink)
Old 11-01-2009, 10:51 PM
Thanks for the replies!!!! Here is a pic of the bracket i would like to use. Im thinking about cutting off just enough of the right side to clear the axle and adding another one just enough inside to reach the axle tube.
Photobucket
__________________
Roger
1955 F100
  #6 (permalink)
Old 11-01-2009, 11:16 PM
F1CORY's Avatar
F1CORY F1CORY is offline
F1CORY is starting off with a positive reputation.
Hey Roger..
That looks a little tight..Is there enough room for the bag?..You could notch those mounts and put them on top of the axle....
  #7 (permalink)
Old 11-01-2009, 11:30 PM
Quote:
Originally Posted by F1CORY View Post
Hey Roger..
Theres enough room left an inch on the frame side. The bag whould sit even with the top of the axle tube. I do not understand what you said about notching the mounts and putting them on top?
__________________
Roger
1955 F100
  #8 (permalink)
Old 11-01-2009, 11:51 PM
F1CORY's Avatar
Umm..I'm much better at talking then typing..lol..Like if you were to cut off the half circle axle mount and notched the bottom so you could weld them to the top instead..would gice more room around it..plus the weld on the pumkin side wouldn't have to be near as strong since it's pushing straight down, not out front trying to twist..
  #9 (permalink)
Old 11-02-2009, 12:39 AM
havi's Avatar
havi havi is offline
Collector of rust
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
Like creating the same bottom profile as a regular leaf spring pad.
__________________
The going, the journey, should be the objective of a trip in a built old Ford, the destination always secondary.
  #10 (permalink)
Old 11-02-2009, 12:50 AM
keith56_cruz_cab's Avatar
keith56_cruz_cab keith56_cruz_cab is offline
keith56_cruz_cab is gaining momentum as a positive member of FTE. keith56_cruz_cab is gaining momentum as a positive member of FTE.
here's a couple pics of mine if it helps same rear end
__________________
going to the darkside.....PRICELESS
  #11 (permalink)
Old 11-02-2009, 08:00 AM
49willard 49willard is offline
49willard is gaining momentum as a positive member of FTE.
Roger, I would not recommend welding on cast iron particularly in the application that you have where significant loads will be on the weld. As discussed above, cast iron welding is very sensitive to preheat and post weld cooldown. I have had cast iron welded (did not do it myself and there is little that I won't tackle). Done properly cast iron rod is used to weld cast iron. The people that do it for a business will acturally weld in an oven with the whole piece very hot and then control the very gradual cooldown of the entire piece in the oven. All of this is done to control cracking and is the reason that it is expensive to have done. If it was easy lots of us would do it. It looks like you are looking at a dissimilar weld to boot, i.e. mild steel to cast iron. I really do not think that you want to go there. I only know enough about welding cast iron to avoid it or go to someone who does it in the oven as I discussed.
__________________
Bill
  #12 (permalink)
Old 11-02-2009, 08:35 AM
mytbtruck's Avatar
mytbtruck mytbtruck is offline
mytbtruck is starting off with a positive reputation.
I believe tha rear end housing and axle tubes are cast steel not cast iron. All the stock Chevy and Ford rear ends we use for drag racing are cast steel and you can weld on them. I don't think a cast iron housing was used for rear ends. I could be wrong but check it out.
  #13 (permalink)
Old 11-02-2009, 12:19 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage is starting off with a positive reputation.
Ditto. I think so, too. As the O.P. mentioned, the tubes were plug welded into them from the factory and I see guys weld new tubes in all the time when modifying them. They usually weld the tubes to the housing all the way around rather than just plug weld them and I'm positive that they aren't using cast iron welding techniques. Try this: pick an inconspicuous area on one of the housing webs. Chuck an 1/8th inch drill bit up and drill a shallow hole while observing the drilling waste. If the metal comes out of the hole as a powder, then it's cast iron. If it comes out in chips or shavings, then it's cast steel and can be welded without much trouble.
__________________
Let's agree to respect each others views, no matter how wrong yours may be.
  #14 (permalink)
Old 11-02-2009, 12:38 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has a good reputation on FTE. AXracer has a good reputation on FTE.
I'm really curious why y'all put the air springs to the inside of the frame and the 4 bars on the outside? My sensibility and suspension experience says it should be the other way around. All the leverage arm produced by the pavement contact patch distance from the bag centerline and the narrow space between the bags will produce more of a twisting rolling motion than an up and down motion resulting in the truck rocking like a rowboat in a storm. I would have mounted the top mount at the top of the frame kickup on the outside of the frame and the lower mount to the top of the axle, and mount the 4 bar at the inside of the frame. That would produce a lot less twisting force on both the bags and the bars. But that's just me.
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP racer, the "KRAZED KANARY"
2002 Celica GT 2003 GSL National Champion retired to daily driving duties
  #15 (permalink)
Old 11-02-2009, 02:52 PM
rockher_man's Avatar
rockher_man rockher_man is offline
1956 Ford F-100
rockher_man is starting off with a positive reputation.
Lightbulb BRACKETS.....
...keep it simple...you are over-thinking it man.......
THESE lower air bag brackets are availble from Air Rie tec....or what ever they are calling themselves today....
THIS bracket was designed to BOLT to their rear lower 4-bar bracket that is welded to the axle tube...
ALSO...notice the SHOCK mount BOLTS up to the lower bag bracket...
Cannot get much eaiser that that......I hope this helps...
__________________
Gimme Fuel...Gimme Fire...Gimme that which I desire...
Vintage '63-64 Buddy Barr/Holley Triple-Duce...
TOTAL cfm = 730
Tags
88 , axle , bagged , cast , center , end , f100 , ford , made , rear , section , steel , techniques , tubes , welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
