Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-02-2009, 05:48 PM
thepitshop's Avatar
thepitshop thepitshop is offline
thepitshop is starting off with a positive reputation.
i installed mine on the top of the axle similar to keith`s pictures, i had the bags on the outside but they were just too big and took too mutch room. if i remember correctly the bag diameter was 4 inches, compressed you added 1 inch each side, 1 inch clearance between the frame, 1 inch between the tire=8 inches, there was no way i could fit a decent piece of wide rubber, as for axle tubes there not cast,they can be welded on!
__________________
55 ford f100, stock
crown vic frt end
4 link, bagged!
  #17 (permalink)
Old 11-02-2009, 05:52 PM
thepitshop's Avatar
here`s an old picture of mine before boxing in the frame and a bit of clean up
__________________
55 ford f100, stock
crown vic frt end
4 link, bagged!
  #18 (permalink)
Old 11-02-2009, 08:25 PM
e-tek's Avatar
e-tek e-tek is offline
e-tek is starting off with a positive reputation.
You guys with the bags are making some NICE stuff!!
  #19 (permalink)
Old 11-02-2009, 11:34 PM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
1956 Ford F-100
BACAGrizz is gaining momentum as a positive member of FTE.
Looking at your project from above , your best bet, and probably the easiest thing to do, might be to emulate what Rockher_man has done and weld those air bag brackets to the backside of the 4-bar brackets and mount the bags to the rear of the axle outside the frame.
__________________
Central Oklahoma Chapter
No Child Deserves to Live in Fear.
1956 F-100 289 w/ 460 warming in the wings.
2006 H-D FLHXI, 95" stage 2.
  #20 (permalink)
Old 11-02-2009, 11:38 PM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is offline
rtcalabrojr is starting off with a positive reputation.
Quote:
no room outside the frame rail. I either keep what i have or i have but different airbags for the rear.
__________________
Roger
1955 F100
I smell cookies! click to check out the truck
http://s919.photobucket.com/albums/ad37/rtcalabrojr/
  #21 (permalink)
Old 11-02-2009, 11:54 PM
Farmboy46's Avatar
Farmboy46 Farmboy46 is offline
Farmboy46 is starting off with a positive reputation.
Ive welded to cast center sections and never had a problem yet. It should be fine.
  #22 (permalink)
Old 11-03-2009, 12:15 AM
SunDown's Avatar
SunDown SunDown is offline
SunDown is starting off with a positive reputation.
mount the airbags in the center just directly behind the rear axle and run a rocker arm or cantilever system from the bags over to the axle ends where you were going ot mount the bag brackets. Space problem solved and it would look WAY more trick!
__________________
Proud member of No Sympathy truck club
  #23 (permalink)
Old 11-03-2009, 08:43 AM
thepitshop's Avatar
Quote:
you`d have to mount them in the front of the axle , the rear has the fuel tank and cross member, that would look trick Sundown!
__________________
55 ford f100, stock
crown vic frt end
4 link, bagged!
  #24 (permalink)
Old 11-03-2009, 09:15 AM
BACAGrizz's Avatar
1956 Ford F-100
In the picture there are 2 pad looking things on the back of the diff that appear to be directly under the frame on each side. Would it be possible to weld the brackets to the lower part of those behind the axle tubes and then have the upper brackets on the frame and have it work that way?
__________________
  #25 (permalink)
Old 11-03-2009, 09:54 PM
THose tabs are gone now! They where for the sway bar. There is no room on the back side. I would have to remove the rear crossmember and relocate the gas tank setup i have already.
__________________
Roger
1955 F100
  #26 (permalink)
Old 11-03-2009, 09:57 PM
I like the idea but dont really know how to go about it? I see pics on line but thats it. Have any pics with dimensions? Im open to any ideas, as long as they work!!lol
__________________
Roger
1955 F100
  #27 (permalink)
Old 11-04-2009, 12:45 AM
SunDown's Avatar
They work, mini truckers have been using the design idea for a few years now. Carts and F1 and Indy types also use this idea with springs instead of bags, though thier designs are more advanced than what I am thinking of. I dont have any diamensional info to give you, that would be up to you to decide based off of where you would want to put the bags.
The bag behind the axle might not work in your case, cause of the fuel cell and what not, but that doesn't mean you cant run the bags in front of the axle along side and inside the frame.
Think of a rocker arm in your valve train for the basic idea. Design a rocker arm for the suspension where the bag side from the pivot point of the arm is shorter than the axle side to the pivot point. That will put the bag in a mechanical advantage and give you a nice ride. If you make a rocker arm that puts the bag in a 1 to 1 ratio, where both sides of the pivot out measure the same, it will be like putting the bag right on top of the axle, giving you a crappy ride, but it will work. I would make sure the bag side of the rocker is shorter thant he axle side, better ride and more lift out of the rear axle that way.
As for where it would go, you have what appears to be quite a bit of frame real estate sitting there in front of the axle that could be used to hang the bag bracket off of and the center pivot would need to be mounted to something very stable like a cross bar or an additional crossmember.
If you have a tubing bender or a friend with one, I would have a crossmember bent out of tube with a bend in the middle for the drive shaft to clear. You can weld on the end plates and then either weld the crossmember to the frame rails or bolt it in.
as for drawings, I don't have any myself, but you could do one vehicle specific with the diamentions you have to work with.
I would love to run something exotic like this on my 55 and I just might, I am just not there yet though.
__________________
Tags
88 , axle , bagged , cast , center , end , f100 , ford , made , rear , section , steel , techniques , tubes , welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
