Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 08:42 PM
Bodger's Avatar
Bodger Bodger is offline
Bodger is starting off with a positive reputation.
Is a straight pipe for 6.0 a good idea ???
Hello to all, Im new here and still finding my way around.
Just thought i would see what you think about a sraight pipe will it give me more power or loose it. Also ive just read what people thought about the edge tuner I have one with the Attitude controler. I keep it on the mileage setting.
Let me know what you think please
.Its got to go into Fords in the morning for an injector or two, not sure why they failed i do all i should do.
Thanks for your time..........
  #2 (permalink)
Old 11-01-2009, 11:09 PM
ford7379trucks ford7379trucks is offline
ford7379trucks is starting off with a positive reputation.
yes on the strait pipe. you will gain a little power but lower exhaust temps is the best thing about it. Ditch the edge. Edge doesn't care about your truck just advertising big numbers. They will kill your trany and blow head gaskets. Do a search and you will find lots of info on here.
__________________
2003 F250SD 4x4 6.0L 5 Speed Auto 12/03 flash
Who needs a radio when you got a turbo diesel?
The only difference between o bama and osama is BS.
FUBO
  #3 (permalink)
Old 11-01-2009, 11:23 PM
mojo1's Avatar
mojo1 mojo1 is offline
mojo1 is starting off with a positive reputation.
I have mine straight piped. The biggest thing i like is the sound and the whistle of the turbo. The lower egt's is a big plus also. Everthing else is stock.
__________________
GREG
2006 F-250 PSD CC LARIAT FX4
2006 NISSAN MURANO
  #4 (permalink)
Old 11-02-2009, 07:25 AM
mh5500 mh5500 is offline
mh5500 is starting off with a positive reputation.
Can you just gut the cat if you want? Will that help or hurt?
  #5 (permalink)
Old 11-02-2009, 08:33 AM
you can gut the cat but you should run a pipe thru it or it mite sound funny.
__________________
FUBO
  #6 (permalink)
Old 11-02-2009, 09:00 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
HeavyAssault is gaining momentum as a positive member of FTE. HeavyAssault is gaining momentum as a positive member of FTE.
Straight piping my 6.0 was the second best decision I ever made next to getting divorced.
I used the MBRP 3.5" down pipe and MBRP cat delete pipe then I cut out the muffler. I get looks and thumbs up all the time. It has a slight whistle at idle, a decent whistle just moving the truck around and a serious V8 rumble when hitting the pedal.
__________________
http://i257.photobucket.com/albums/hh239/HeavyAssaultF350/DSC00396-1.jpg
  #7 (permalink)
Old 11-02-2009, 10:34 AM
So you don't need back pressure for the turbo? I'm I thinking right?
  #8 (permalink)
Old 11-02-2009, 10:56 AM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
The turbo provides the back pressure for the motor, if you can reduce pressure after the turbo it makes the turbo more efficient. Personally, I would keep a muffler since I don't want to annoy my neighbors.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #9 (permalink)
Old 11-02-2009, 04:18 PM
Can't I just cut the cat out and use flex pipe and 2 band clamps?
  #10 (permalink)
Old 11-02-2009, 07:32 PM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench is gaining momentum as a positive member of FTE. Benchwrench is gaining momentum as a positive member of FTE.
if you use flex it disrupts the flow and will most likely gain some type of whistle as it passes over the flex.
Using Flex - bad idea
Straight pipe - eh, o.k. if your under age or live down south
adding a muffler - best note
__________________
2006 F-350
Sept. 2001 NY was an inside job. do a video.Google search of: WTC # 7
oh yea, the military targets & tortures civilians with GPS satellite weaponry which is highly advanced,
more so than you're willing to believe, but very real and true nevertheless.
  #11 (permalink)
Old 11-02-2009, 08:04 PM
There's no point cutting out the cat and using flex since the cat unbolts easily. Just use a delete pipe or take it out, gut it, and put it back on.
__________________
  #12 (permalink)
Old 11-02-2009, 09:37 PM
Bodger's Avatar
I was told today that Fords sell a complete straight pipe system. Abuddy of mine just got one for his 6.4 because he wrecked his stock one.
  #13 (permalink)
Old 11-03-2009, 10:42 AM
Culvert Culvert is offline
Culvert is starting off with a positive reputation.
How many degrees will you drop in EGT by going with a straight pipe? How loud is the truck after with no muffler?
__________________
06 F350 6.0L CC FX4
01 Windstar Sport
66 Fairlane 500XL
  #14 (permalink)
Old 11-03-2009, 11:07 AM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
I just don't know how to take that.
Quote:
That varies a little bit between vehicles and if you are running a tuner or not. ~200 degrees isn't far fetch if you go with a 4" system straight-piped.
As to sound with no muffler, on my it wasn't really all that much of improvement, although I have to say this, I have blown my eardrums out in my youth running Dio songs a little too loud.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #15 (permalink)
Old 11-03-2009, 01:00 PM
zhilton's Avatar
zhilton zhilton is online now
2004 Ford F-250
My Garage
zhilton is starting off with a positive reputation.
Quote:
Exactly, I like my neighbors...and we try to get along. They don't want me to come in or leave at all hours of the night. And I don't want to hear that "Hemi Heep" either. I figure when the Hemi has a heart attack I'll do my best to convert him from the dark side.
__________________
1972 Ranchero GT 351C (Engine code "Q")
2001 Explorer XLT 2WD
2004 F250 PSD CC Lariat 2WD "Pavement Princess" (bone stock...for now)
Tags
03 , 60 , 60l , back , code , exhaust , f250 , ford , good , pipe , piped , piping , sound , stock , straight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
