Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 08:41 PM
abah abah is offline
abah is starting off with a positive reputation.
caliper/rotor replacement
The shop I used recently checked my brakes cause they were squealing. Told me calipers were locking up on front wheels so then told me I need new calipers, rotors, flex lines and brake pads...$632. They were going to get parts from ford dearlership. I have a friend that told me he would do it for me for far cheaper at his home but my question is should I buy the parts from ford or are the parts at autozone or advanced just as as good as the oem? Only 50,644 miles and having to do this already.
  #2 (permalink)
Old 11-01-2009, 09:08 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
Brake pads: if you don't like all the dust, there are better choices than OEM.
Rotors: if you're talking 2wd, results have been mixed at best. Some folks have done fine with non-OEM parts. Others will never buy anything but OEM again after poor results. If you want drilled/slotted rotors, you're looking at aftermarket.
I haven't seen much discussion about the quality of calipers or flex lines.
__________________
2007 F150 SCab Lariat 5.4L 4x4
1995 Ranger XLT 4.0L 4x2 LB
  #3 (permalink)
Old 11-01-2009, 09:21 PM
Thanks. After reading about the Power Stop Cross drilled and slotted rotors I kinda want to try these, they dont cost much more than a pair at autozone and apparently they are better than regular rotors. Anybody have a set?
  #4 (permalink)
Old 11-01-2009, 11:00 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
I've had them on 3 vehicles and LOVED them.....i'd get those rotors and buy akebono pads.....
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #5 (permalink)
Old 11-02-2009, 12:01 AM
fireman28's Avatar
fireman28 fireman28 is offline
fireman28 is starting off with a positive reputation.
I just did mine a few weeks ago and used Napa Ultra Priemium rotors and Adaptive One pads. I love them so far. I have towed with them and have no brake dust. Just another one to look at.
__________________
'07 F-150 SuperCrew Lariat 4x4 Dark Stone
-07 ExpeditionEL Limited Dark Shadow Grey - Traded
-07 F350 KR Dually FX4 Diesel CC True Blue -Traded
  #6 (permalink)
Old 11-02-2009, 06:33 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
I changed my '04 2WD rotors at 83K with the NAPA Performance rotors which are drilled and slotted. Also, made in the USA. I used Wagner ThermoQuiet ceramic pads. I did not need calipers but flushed my entire brake system to refresh the fluid. The rear pads I replaced at about 40k. By the way the rotors are the same as Raybestos brand and cost about $245/each plus tax.
  #7 (permalink)
Old 11-02-2009, 08:00 AM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Something doesn't sound right. Why do you need to replace everything from the steel lines outwards? Are the rotors scored badly? Are the caliper pistons stuck? Are the calipers not sliding? Are the lines cracked? I would suggest that you get another mechanic to look at the brakes.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #8 (permalink)
Old 11-02-2009, 10:57 AM
your right i probably should have another shop look at it. one of the seals on the right front caliper piston was torn so i guess that was causing the thing to stick. I did myself notice an unusual amount of heat coming from both of my front tires. The shop said both calipers were sticking and both rotors were warped and they need to be replaced. I am going to have a second opinion before I order any parts. Thanks for everyones information.
Tags
2003 , 2008 , 4x4 , caliper , chat , f150 , ford , removal , replacement , rotor , rotors , supercrew , tool , triton , truck , trucks , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
