Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 08:34 PM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 is starting off with a positive reputation.
did I do any damage
I was driving across a field to my next hunting spot and suddenly found myself in the middle of a mudhole and loosing speed fast. I let off the gas and qiuck hit the 4x4 and got back on the gas to keep momentum, but the 4x4 didn't engage right away and when it did it slammed in. It sounded like it was the transfer case that made the noise. the only thing I can think of was that I didn't let off the gas long enough while engaging the 4x4 and it couldn't shift because of driveline torque. The speedo was showing around 15mph when it slammed in, but forward speed wasn't that much because I was spinning a little. do you think it might have damaged anything? I continued using the 4x4 and it worked fine afterwards with no unusual noises.
  #2 (permalink)
Old 11-01-2009, 09:20 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
If it still shifts in/out fine, chances are that nothing was damaged. I wouldn't spend too much time worrying about it, just try to get it into 4wd before you really need it to know it still works.
__________________
2007 F150 SCab Lariat 5.4L 4x4
1995 Ranger XLT 4.0L 4x2 LB
  #3 (permalink)
Old 11-02-2009, 06:57 AM
dixiemudder04's Avatar
dixiemudder04 dixiemudder04 is offline
2006 Ford F-150
dixiemudder04 is starting off with a positive reputation.
I thought u could engage in 4x4 while u was driving. The dealer showed me and my dad that. He said dont get about 50 and you're ok.
__________________
2006 Ford F150 Ext cab, long bed, 4x4, 4.10 w/ limited slip, 5.4L triton, K&N filter, 2.5" AS leveling kit, 1 chamber mufflers with 45* 4" tips out to the side, 17x8 eagle alloy bullet holes, 20% tint, 305/70/17 nitto a/t's
  #4 (permalink)
Old 11-02-2009, 10:27 AM
VFR_Man's Avatar
While all wheels are moving at the same speed, yes. The clunk he heard was likely due to the front wheels not moving as fast as the spinning rear wheels when the transfer case shifted.
__________________
  #5 (permalink)
Old 11-11-2009, 09:22 PM
eatingdead's Avatar
eatingdead eatingdead is offline
2007 Ford F-150
eatingdead is starting off with a positive reputation.
don't worry, built ford tough right??? Have done that many times in my work truck 350 diesel. Doesn't seem to bother it. Just keeps pluging along like the day I bought it in 99.
Tags
damage , fast , speeds , spinning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
