Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 08:34 PM
RaggedyAnne RaggedyAnne is offline
RaggedyAnne is starting off with a positive reputation.
Question Can anyone help?
Hi, I have a 2005 F150 5.4 liter FX4.. I had an incident where a tree fell on my truck, breaking off the passenger side mirror and now I don't have brake lights or turning signals. The insurance company wants to charge me an arm and a leg to fix it. I have tried changing fuses and had no luck. does anyone have any advice for me?
  #2 (permalink)
Old 11-01-2009, 09:35 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
All that was damaged was the mirror? Has the mirror been replaced? If not, did you try disconnecting the wiring harness from the damaged mirror first and then checking the appropriate fuses?
I would hope the fuses would protect the system from what appears to be a short, but I'm not completely familiar with those circuits either.
__________________
2007 F150 SCab Lariat 5.4L 4x4
1995 Ranger XLT 4.0L 4x2 LB
  #3 (permalink)
Old 11-01-2009, 09:41 PM
Yes, that was all that was damaged. I Haven't been able to afford to replace the mirror yet.
  #4 (permalink)
Old 11-01-2009, 09:45 PM
VFR_Man's Avatar
If you take the door panel off, there is a connector for the mirror wiring that you can disconnect. If there is a short in the mirror, that would cure the short at least.
__________________
  #5 (permalink)
Old 11-01-2009, 09:47 PM
Thank you, I will try that
  #6 (permalink)
Old 11-01-2009, 10:35 PM
stronger stronger is offline
stronger is starting off with a positive reputation.
I agree, but removing that panel is a bit of work. do a search on here "door panel removal" somebody made up a nice "how to" a while back. if it was me and the mirror was already trashed, why not just locate the wires (they must be hanging out now?) on the outside of the truck and just Cut them. then separate and tape them up. that would only work if its obvious that your not cutting into the Truck portion of the harness.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
