Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 07:01 PM
YoungFordAddict66 YoungFordAddict66 is offline
YoungFordAddict66 is starting off with a positive reputation.
SAS on 95 PSD
so i was told it would be better to put in a front solid axle dana 60 on my new 95 psd f250 xl if i wanted to lift it 4 inches. so my questions are what years and types of trucks can i take one from? how long does it take? and what is the procedure? just filll me in on everything you know that would be great thanks.
__________________
Pardon me chevy. Excuse me dodge! Ahhh just get the hell out my way before i run you both over!
1978 F-250 supercab, 400m, 4X4, 650 Edelbrock, Cherry Bombs, Headers
My new baby 1995 Powerstroke supercab, 4X4, Garret Turbo
  #2 (permalink)
Old 11-01-2009, 07:15 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
my first question is why do you want a dana 60 over the independent front end???? the 50 is much nicer on the road and when set up right wont wear the tires and really does well offroad.
if i cant change your mind then any dana 60 out of a single wheeled ford truck will work. the older ones are kingpin and the newer ones are balljoints. if it were me i would get the balljoint style which would be mid 80's up to 97. also, the price you will spend on just the dana 60 and associated hardware to install it is more then a lift kit and front end rebuild for your current set up.........
the dana 50 is a good strong axle and you can get posi's for them and i thik lockers now too. lift kits are all over the place for them and really perform great. here is my setup on the dana 50.(note the tire wear--->perfect)
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #3 (permalink)
Old 11-01-2009, 08:11 PM
well i was told that a dana 60 was a must if i wanted to lift it idk its just what i was told by the fte guys. this is my first psd and my first independent front suspension anxle so im not familiar with them.
__________________
  #4 (permalink)
Old 11-01-2009, 08:19 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry jimwilsonmasonry is offline
jimwilsonmasonry is starting off with a positive reputation.
dang c00n you got some articulation in them bottom couple pics looks good
__________________
I have a 96 psd with 302k miles,3:55s, cc ,5" stack,e4od-shift kit ,2wd,k&n intake 3" dp, ccv mod,no cat, hotpedal,140v idm,hpx,tw 6 pos chip, gauges,maxi cool xl trans cooler,305x70x16 tires,ported intake---94 trans am lt1 lots of bolt ons
  #5 (permalink)
most people dont like it because it has got a bad reputation for eating front tires. the potential is there for tis to happen but as long as your bushings are not wore out and your alignment is set correctly (not just "in the green") then you will be very pleased with it. like i said, i have 6 inches of lift on my truck with no issues. i would also reccomend that if you are lifting the truck then go with a 6inch instead of a 4 inch. its virtually the same price and the springs are better on the 6 inch kit and you can get the heavy duty axle pivot drop bracket---> 2 must have's for the diesel trucks.
__________________
  #6 (permalink)
Old 11-01-2009, 08:22 PM
Quote:
thanks, i took those pics a while back when this sort of topic came up before. people saying the dana 50 is junk and you cant go offroad with the independent front end. for the twisted up pic the truck is actually only in 2wd! i kept 3 tires on flat ground and rode the right front up as high as it would go in 2wd before the rear axle opened up. i could have gone farther but not in 2wd.
__________________
  #7 (permalink)
Old 11-01-2009, 08:34 PM
is that a skyjacker lift kit? and did u install it yourself or did you have someone else do it? and if the 6 inch is tougher than i might get that but i really didnt want it that high.
__________________
  #8 (permalink)
Old 11-01-2009, 09:21 PM
rideracelivemx7 rideracelivemx7 is offline
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
joe how did you get your front end to not bow down and point the tires down? when i did my springs, i had an extra leaf thrown in there as well as the stock spacers below the center bolt and it was to high and the middle of that dang axel split and bowed so much it pointed the tires down so much that it looked so terrible i parked the truck and ripped out the springs and fixed it that day.
__________________
red 7.3 powerstroke diesel-6637-10k-6 POS chip big name tunes-HPX line-3" Downpipe--> 6" Aussie stacks! 3:55s auto-122k miles-Rotella Synthetic, ebpv butterfly removed
  #9 (permalink)
Old 11-01-2009, 09:37 PM
young ford, yes that is the skyjacker kit, springs frotn and rear, not blocks out back. i got the heavy duty kit. the difference is in the axle drop bracket. mine is the large one peice reinforced unit and the light duty is 2 peices that are prone to flexing and cracking. i have installed many lift ktis, they are not hard, just takes a little time. airtools and lifts make it much easier. when you think about it there's only a 2 inch difference.
riderace- what kit did you buy? that makes a big difference in the quailty. skyjacker did their homework, its a badass setup. my axle's ride level and i can use the standard balljoint bushings for alignments. no crazy offsets to get it in spec. i just replaced my front spring bushings so i need to get it aligned. when i do i will post what my end specs are and what shims i had to use. i will also take more detailed photos of the lift and how things sit in there.
__________________
  #10 (permalink)
Old 11-01-2009, 09:46 PM
1995 Ford F-250
i didnt get a lift kit, i had a buddy at a spring shop help me out on the old springs and added a leaf the the old 250 springs out of the 350 springs i got just to get my height back,it rode on the load busters for a good while and looked really bad, but i was inexperienced dealing with the d50, i didnt want to over lift it, i love the stock look. dont get me wrong, your truck looks awsome but im baffled how yours didnt bow, i havce all new hardware and bushings. its all set now but even a half of a inch of lift and it bows
__________________
  #11 (permalink)
Old 11-01-2009, 11:11 PM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
when you do a TTB lift
The drop brackets are the MOST important part.
if you do not put these in, every bump you hit will move the tires around and jerk the stearing.
bad camber.
TTB lifts must be done correctly if you value your saftey.
Putting just springs in there is not correct. You must drop the pivot points down.
the TTB setup is a great setup when working properly. I am probably the only one on here who likes them becides coon.
BUT.
I would rather have a d60 for simplicity purposes. I will most likely end up fixing my d50 front with bigger springs and possibly a lift kit, but not as much as coon.
most likely a 2 inch lift with bigger springs, or just a leveling kit.
I have a broken spring as well. so that is inspiration to get going on it.
The TTB is great for trail riding and everything. They handle great, and are better then the chevy/dodge equivalents. All day every day.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
Quote:
Originally Posted by Action4478
the columns aren't made out of marshmallows...Just wiggle it ....
  #12 (permalink)
Old 11-01-2009, 11:17 PM
the key withthe lift is in my second picture, the large red bracketry. it drops the axle pivots and re-centers tehm with the lift springs
__________________
  #13 (permalink)
Old 11-02-2009, 03:14 AM
Oversize's Avatar
Oversize Oversize is offline
1996 Ford F-250
Oversize is gaining momentum as a positive member of FTE.
Ive still got my d50 and never had a problem w/ it the only reason Id concider changing it is simplicity of design, combined with strength, and reliabilty. But like Coon mines works great and its lifted. (knocking on my wooden desk)
__________________
96 F-250 HD, SC, LB, 7.3 DI Diesel, 5 spd, 6" lift, 35" AT's, 3" DP, cat gut, 6" straight pipe, 4.10's, FPR shim, custom intake, Hot pedal, HPX, Pyro, Boost, ...
Professional driver, Former CAT and Industrial Mech, P/T race engineer.
  #14 (permalink)
Old 11-02-2009, 11:27 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
If you do decide to go with a D60 you will need all the steering linkage and other hardware from the D60 truck. It will bolt in pretty easy and it's a great setup to have if you put your truck through a lot of abuse.
The D50 is a good axle if you set it up right though...
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #15 (permalink)
Old 11-02-2009, 12:55 PM
1995 Ford F-250
i just wan to set it straight, i wasn't trying to lift my truck at all, just get my factory ride height back thats all, it was a battle ill say that!
__________________
Tags
150 , 1994 , 1995 , 97 , f250 , ford , powerstroke , pricing , sas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
