well i have never lifted a truck before on my own and this sounds like its not a good one to start on. so maybe i'll buy the kit and take it to les schwabs and have them do it or just not do it at all still in the thinking process.
__________________
Pardon me chevy. Excuse me dodge! Ahhh just get the hell out my way before i run you both over!
1978 F-250 supercab, 400m, 4X4, 650 Edelbrock, Cherry Bombs, Headers
My new baby 1995 Powerstroke supercab, 4X4, Garret Turbo
Lifting a TTB isn't bad.
Just nobody thinks to lower the piviot points to match the leaf springs.
They short cut, like the guy talked about earlier, and just put big ole narly springs on it, and then the camber is messed up.
Every bump you hit, the tires move in and out, and do all sorts of squirly things. the truck will jerk around the road. yada yada.
Get under the truck and look at how the TTB system works. You just have to unbolt some things and drop them down.
Dont forget your new brake hoses for the front also.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
dude, call skyjacker, their number is (318) 388-0816
tell them what you want to do and they have the kit you will want. if you want to go cheaper then get a kit with rear blocks. the kit's with rear springs are smoother in my opinion but thats just me. the block rears will work for the avg guy who just wants a big truck and spends most of his time on roads. for example- here is a kit that will pretty much work for you depending on what your truck is equipped with......ie sway bars and such... the only other things you need to buy are shocks and extened brake lines---->all of which they have.
5 minutes on their site got me the above part numbers for basicly everything you would need to make your truck pretty badass....lol i'm telling ya, just give them a call
does anyone know a place that just sells the drop brackets thats all i would need springs are easy to come by
__________________
1994 F250 5 speed 7.3 idi turbo 4:10 gears 4X4 XLT Extended cab long box
240k 1988 with a 92 to 96 front end full size bronco 4x4 with dana 60 front 10.25 rear 4:10 gears 5 speed 351 with a cummins turbo! and about a foot of lift 1987 F150 long box reg cab 9 '' lift 460ci 4x4 4:10 gears 38.5 baja claws
