Go Back   Ford Truck Enthusiasts Forums > General > The Next Generation
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The Next Generation For those ages 15-25.
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 06:31 PM
mstiles19's Avatar
mstiles19 mstiles19 is offline
mstiles19 is starting off with a positive reputation.
Hot Tub
I am trying to figure out how to create a hot tub in the bed of my truck. In the past i have made a pool by putting a tarp in the back and filling with water but now i want to heat it for winter use. Do you guys have any ideas?
I was thinking about hooking up a pump to a hose that i can run through a coil in a 55gal drum which i will burn wood in. What do you think?
__________________
Matt
2001 5.4L F-250 SuperDuty
1989 jeep wrangler
VIDEO OF MY BACKYARD
  #2 (permalink)
Old 11-01-2009, 08:18 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
of RiffRaff
7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE.
Pipe from the exhaust into the water? hot exhaust = heat + bubbles?
__________________
-Pete, PAA member #84
99.5 F350 XLT 4x4 regular cab longbed 7.3L PowerStroke 4" MBRP turbo-back, Isspros, 6637 w/ cover, CCV, AIH delete, foil delete, 6.0 IC, Van turbo, RDP IC boots, DP Tuner
Smoke Responsibly
  #3 (permalink)
Old 11-01-2009, 10:31 PM
mstiles19's Avatar
Quote:
but i dont think that would heat up the water enough
What i was thinking was taking a bilge pump(or something similar) and hooking it up to a pipe that runs through hot coals. My only problem with this is that I think copper line is too thin to pass a large amount of water and if i was to sweat copper pipes together in the coals they would just come apart.
__________________
Matt
1989 jeep wrangler
  #4 (permalink)
Old 11-02-2009, 08:36 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of
Hot tubs loose heat at a high rate especially in winter. Adding air (for bubbles) really takes the heat out of them. Even 220V hot tubs take hours to get up to temp and then struggle at holding it when the cover is off. Takes big heat to keep one cooking.
Are you just planning on filling it hot and then going or do you want it to produce heat while on the road?
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #5 (permalink)
Old 11-02-2009, 11:13 PM
mstiles19's Avatar
no just when it is parked in my driveway. I have driven with my bed full to the brim with water before and it was reckless. When i hit the brakes I had a tidal wave come over the top of my truck. This setup will be totally temporary.
If you have ever burned wood in a oil drum it really does produce alot of energy. It can burn for days after putting in the last piece of wood. I just want to figure out how to harness the heat to warm the water.
__________________
Matt
1989 jeep wrangler
  #6 (permalink)
Old 11-06-2009, 12:20 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a good reputation on FTE. twags6 has a good reputation on FTE.
Use your wood burning barrel and see if you can get the copper pipe that bends by hand. I wanna say its type M, but I'm probably wrong. That way you can make one continuous coil and keep the fittings outside the burner. Pick up a small pool pump or just a cheapo pump at harbor freight. 1/2 to 3/4 should do. If you get too small of one, the water might cool down before it gets a chance to heat up the stuff in the bed.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 152k
PAA Member #7
Tags
bed , f250 , hot , make , truck , tub
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
