Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 06:02 PM
0351mike 0351mike is offline
0351mike is starting off with a positive reputation.
how to identify upgraded ignition system?
I was hoping to get a little guidence. I have a 70 wagon with a 75 302 in it. I wanted to replace the control modual and voltage reg. I had thought
Ford upgraded the ignition sytem including the distributor between 70-73.
How do I identify if my 70 have the original stuff in it? Does it matter if I replace it with replacement parts from a 75?
  #2 (permalink)
Old 11-02-2009, 09:24 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
70 had points distributor, 1 wire. Duraspark has three wires and the control module. If buying a new control module, just get one for a 76-77 302 w/ blue connector on the module. They're interchangable, but the older module has three wires heading to dash instead of two (red and white).
__________________
76 Bronco Explorer 289 Hi-Po
66 Bronco Half Cab 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp. 4:11 gears-3 speed
  #3 (permalink)
Old 11-02-2009, 10:04 AM
Control module
Thanks for the info! When these go bad do they ever intermittenly work or when they go- it's dead?
  #4 (permalink)
Old 11-02-2009, 10:28 AM
gfw1985's Avatar
Usually dead, but I did have one that would idle only if I remember right. That one was a long time ago.
  #5 (permalink)
Old 11-05-2009, 12:50 PM
Broncoholic1's Avatar
Broncoholic1 Broncoholic1 is offline
Broncoholic1 is gaining momentum as a positive member of FTE. Broncoholic1 is gaining momentum as a positive member of FTE.
Always keep one in the glove box for a spare. They are great till they die.
Some never die...
__________________
Ford Trucks are Like Lay's Potato Chips, You can't have just 1
69 Bronco 1/2 cab, 71 Bronco Wagon, 76 Bronco , 77 Bronco 1976, F250 Highboy, 1979 F150 SB, 1979 F150 SB Mudder, 1989 F250 2wd, 1979 F350 Monster 5.9 1999 F250 SD V10, 1988 Conquest Class A
  #6 (permalink)
Old 11-05-2009, 03:31 PM
help?
I am trying to figue out why my 70 bronco keeps shutting off on the highway. It will start back up when it cools off- I have a spare control module- so I was going to try that- how about the distributor pick up- would it cut out if it gets hot? How about vacuum in the tank. Both tanks are original 70 non evap-I did put new gas caps on and asked for 70 models from LMC truck- but never really took notice. If these caps were not vented- could it cause the truck to crap out?
  #7 (permalink)
Old 11-15-2009, 08:13 AM
Might be getting too hot & the fuel is boiling???
How long till it dies?
__________________
  #8 (permalink)
Old 11-15-2009, 10:25 AM
gfw1985's Avatar
Building vacuum in the tank is easy to tell. When you loosen gas cap you will hear it sucking air plus lack of fuel in filter if you are using a see thru filter. If you have an ohmeter you can test the pickup coil. Between orange and purple you should read 400-800 ohms. Between black and orange or purple you should read over 70k ohms.
__________________
Tags
1976 , 1977 , 1988 , 302 , 79 , control , distributor , electronic , ford , identifying , ignition , module , system , truck , wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
