I was hoping to get a little guidence. I have a 70 wagon with a 75 302 in it. I wanted to replace the control modual and voltage reg. I had thought
Ford upgraded the ignition sytem including the distributor between 70-73.
How do I identify if my 70 have the original stuff in it? Does it matter if I replace it with replacement parts from a 75?
70 had points distributor, 1 wire. Duraspark has three wires and the control module. If buying a new control module, just get one for a 76-77 302 w/ blue connector on the module. They're interchangable, but the older module has three wires heading to dash instead of two (red and white).
__________________
76 Bronco Explorer 289 Hi-Po
66 Bronco Half Cab 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp. 4:11 gears-3 speed
I am trying to figue out why my 70 bronco keeps shutting off on the highway. It will start back up when it cools off- I have a spare control module- so I was going to try that- how about the distributor pick up- would it cut out if it gets hot? How about vacuum in the tank. Both tanks are original 70 non evap-I did put new gas caps on and asked for 70 models from LMC truck- but never really took notice. If these caps were not vented- could it cause the truck to crap out?
Building vacuum in the tank is easy to tell. When you loosen gas cap you will hear it sucking air plus lack of fuel in filter if you are using a see thru filter. If you have an ohmeter you can test the pickup coil. Between orange and purple you should read 400-800 ohms. Between black and orange or purple you should read over 70k ohms.
__________________
