Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 05:33 PM
thor96 thor96 is offline
thor96 is starting off with a positive reputation.
Will These Wheels fit my 80 F350?
I just picked up a 1980 F350. It's pretty dang clean for it's age. Anyway I'm looking to upgrade the wheels from the stock steelies. I've done the Forum search and can't get a strait answer. I've heard you can use GM 8 bolt pattern. These are the wheels in question. http://images.craigslist.org/3n53kd3...9f61c615d2.jpg
Any help on this issue will be appreciated.
When I can get a pic of the truck I'll add to the pic thread.
Oh and by the way it's a 4x4 with Dana 60's...if that matters.
  #2 (permalink)
Old 11-01-2009, 10:34 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
The Ford, Dodge and Chevy 8 lug patterns were all the same up to the early to mid 90's. That still doesn't mean they will clear your suspension or brakes.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-01-2009, 11:14 PM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
I do not believe they will. A buddy of mine tried them on his F250 and claimed he couldnt get them to fit right.
  #4 (permalink)
Old 11-01-2009, 11:26 PM
In my research I think I read that they will fit the old 8 lug pattern, but not the new metric bolt pattern. How about the center hole around the hub? I suppose the best thing would be to just try the damn thing and see if it fits. How about the off set, would that be a problem?
  #5 (permalink)
Old 11-02-2009, 09:49 AM
bashby's Avatar
bashby bashby is offline
bashby is gaining momentum as a positive member of FTE.
You wont know for sure unless you try them, if you're sure the bolt pattern is the same I'd break out the jack and lug wrench
__________________
86 F350 2WD Duallie dump. 351W edelbrock cam, carb, d/p intake,C6, D0OE heads. 4.10 gears
  #6 (permalink)
Old 11-02-2009, 11:31 AM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB is gaining momentum as a positive member of FTE.
The chevy center hole is too small, it can be machined out, but, they don't bolt righton.
__________________
92 W250 LE, 4x4/CTD/G360/D60/D70U
89 W250, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25. Turbo no more... Poor thing
86 F350 4x4 Mild 460/T19 D60/welded 10.25/38.5x11 Boggers, Warn 8200 up front, M12000 out back...
It's not what you BUY, It's what you BUILD
  #7 (permalink)
Old 11-02-2009, 09:37 PM
fellro86's Avatar
fellro86 fellro86 is offline
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
As just stated, Chevy uses a bit smaller center hole. Dodge swaps fine, but not the Chevies.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #8 (permalink)
Old 11-02-2009, 09:45 PM
Chitownhillbilly's Avatar
Chitownhillbilly Chitownhillbilly is offline
Chitownhillbilly is starting off with a positive reputation.
Quote:
I'll third that. Only thing I'd add is that "Stock" GM won't fit, but if you find Aftermarkets that are on a Chevy they should. I've never seen aftermarkets made with both size center bores on a 8x6.5 pattern.
  #9 (permalink)
Old 11-02-2009, 10:09 PM
fellro86's Avatar
I thought about that after posting. I was only focusing on those wheels he has. If they are aftermarket wheels, they will bolt. Another thing about those factory wheels is that the 88 up Chevys tend to use a negative offset wheel.
__________________
Iowa Chapter leader
Tags
1986 , 1999 , 2000 , 2002 , 2003 , 2004 , 2005 , f150 , f350 , fit , ford , rims , truck , wheel , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
