Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 05:23 PM
rlosing rlosing is offline
rlosing is starting off with a positive reputation.
2005 F-150 Tongue Weight
I have a 2005 F-150 extended cab and just bough a 7x16 enclosed trailer. The trailre seems to squat my truck 2- 3 inches. I have not measured but it is noticable. I bought it used from a guy who had a lot of shelves in it. My question is, how much should the truck squat with a trailer like this, is the shelves in it causing to much tongue weight? Do I need to add something to the springs to keep it from squatting? Does the truck squat an inch for each 500lbs of weight or something like that?
Thanks
  #2 (permalink)
Old 11-01-2009, 07:13 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Tongue weight should be 15% of the total trailer weight. ie; 2000# trailer should have a tongue weight of 300#. 6000# trailer should give you a tongue weight of 900#. You may need a equalizer hitch to spread the weight to both of your trucks axles. You can also go the airbag route; AirBagIt.com - Air Suspension Kits, Mini-Truck Parts, Sport Compact Parts! Airride, Airsprings, Towing Kits, Lambo Vertical Doors, Airbags.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #3 (permalink)
Old 11-01-2009, 10:54 PM
stronger stronger is offline
stronger is starting off with a positive reputation.
Our 150's are tough but IMo they get the nice ride from having soft springs. dropping down 2-3" doesn't hurt anything. Mine will drop quick like that at first but after the first few inches it seems to drop very little when extra weight is added to the be dor to the trailer. I if I put one sled in my trailer it drops 2", but I can haul 3 sleds, 600-700lbs each and the ttruck doe snot seem to drop anymore. Airbags are neat and dont effect the ride when deflated or minimally inflated but if you dont' need them, why bother. I'd fill up the trailer with whatever you plan to haul and see what happens. then buy a weight distributing hitch.
Tags
2004 , f150 , ford , tong , tongue , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
