Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 04:55 PM
nate5812 nate5812 is offline
nate5812 is starting off with a positive reputation.
Ruined my cam any advice on a new one
Hello guys this is my first post in a long time. Its good to see alot of the same familiar names still around. Also think its awesome people are advancing the performance of these so called boat anchors.
I installed a set of aussies on my truck and it ran great for a day then it started missing. The missing cylinder had beat up the lifters real good so I'm replacing the cam ( comp 268H ). I know about the old reliables 265DEH and XE256H. I noticed edelbrock and crane has cams comparable to these. Just lookin for some good input on cam choice because my truck is 2WD unlike most you guys here. So here's the breakdown; weiand intake, headers, 600 holley, msd pro billet, aussie's, and stock pistons. This truck is just a play toy not a daily driver. I haul stuff in it but no major towing. No muddin or trails. I just have it as a full size with muscle.
So can anyone open my eyes and enlighten me to a better choice than the cams listed above?
  #2 (permalink)
Old 11-01-2009, 05:27 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Only advise I can offer is I've seen too many people go too radical on their cam only to find it doesn't make enough vacuum to run power brakes correctly.
__________________
76 Bronco Explorer 289 Hi-Po
66 Bronco Half Cab 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp. 4:11 gears-3 speed
  #3 (permalink)
Old 11-02-2009, 09:03 AM
mark a.'s Avatar
mark a. mark a. is online now
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Why did the cam go bad ? Push rod length checked ? Valve train geometry checked out ?
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 11-04-2009, 06:10 PM
I'm not sure why the cam ate the lifters on that one cylinder. There is nothing wrong with the push rods. I rebuilt this motor 4 yrs ago and have drove the truck spairingly. Seriously like once or twice a month I drive it. Like I said I put those aussie heads on and got the motor ruining good. The first day i drove it it ate the lifters. Drove it probably 75 miles. The brakes worked fine with the cam I had. It is very similar to the ones I've named except it is a single pattern.
  #5 (permalink)
Old 11-04-2009, 08:48 PM
mark a.'s Avatar
If it worked ok before you put the heads on it must have been something to do with them. I'd check push rod length, valve train geometry, etc especially with changing heads. You don't want to end up back in the same boat wiping out a new cam and lifters.
__________________
  #6 (permalink)
Old 11-05-2009, 06:23 PM
The heads were milled 0.01 and checked at huntsville engines so thats the problem. That small of an milling shouldn't require adjustment of push rod length should it? Only that one cylinder had excessive wear on the lifters. Could over tightening the rocker arms caused this?
  #7 (permalink)
Old 11-05-2009, 06:35 PM
hollenjoe's Avatar
hollenjoe hollenjoe is offline
hollenjoe is starting off with a positive reputation.
hmm... if you wouldve had an excess preload on your rockers, you wouldve had a back fire..
Are you using matching springs? Did you follow the break in instructions of the cam? These are the most comun reasons why a cam lobe would flaten...
exsesivly bad cam bearings could also kill your cam..
__________________
"Drive it like you stole it..."
  #8 (permalink)
Old 11-05-2009, 07:54 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
For cams I would recommend Iskenderian
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #9 (permalink)
Old 11-06-2009, 09:23 PM
mark a.'s Avatar
Quote:
Over tightening a positive stop rocker fulcrum wouldn't cause this. Most all head machining has a effect on push rod length. If the machinest doesn't make all the valve tips the same height then one cylinder could have trouble. You won't know for sure until you check push rod length and lifter preload as well as everything else associated with it.
__________________
  #10 (permalink)
Old 11-09-2009, 09:46 PM
Mark A. I've got stamped rockers so all that fulcrum jargon is over my head. The valves are a new stainless set of 16.
The comments are thought provoking thanks guys. Anybody have any other cam advice? Just looking for some good 2wd drive performance. Maybe more lift?
  #11 (permalink)
Old 11-25-2009, 10:03 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE. danlee has a good reputation on FTE.
What kind of break-in oil did you use? You need an oil with high ZDDP content when you break-in a new flat tappet cam.
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #12 (permalink)
Old 11-25-2009, 10:28 PM
alex211's Avatar
alex211 alex211 is offline
alex211 is starting off with a positive reputation.
I wiped a cam on my cleveland when I had the heads and block ground. It also bent some push rods and broke one. Some shims under the rockers fixed it. So far so good with the new Crane powermax cam.
__________________
1978 Ford F250 4x4, Built 351 Cleveland, C6, NP205, Rear Dana 60, Front high pinion Dana 44
http://i152.photobucket.com/albums/s165/photoalexw/1978%20Ford%20F250%204x4/Sig_truck-1-1.jpg
  #13 (permalink)
Old 12-02-2009, 10:33 PM
Countrywfo's Avatar
Countrywfo Countrywfo is offline
Countrywfo is starting off with a positive reputation.
I have a custom grind in mine and it works great on the street. I'll post the specs tomorrow but the rpm range is like 1800- 6200 i believe. I also bent all my pushrods, i went back with elgin 4130 cromoly ones
Tags
mycams1com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
