Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 04:09 PM
lucas1949 lucas1949 is offline
lucas1949 is starting off with a positive reputation.
93 Bronco engine swap
I have a 93 Bronco with a 302. The engine is shot and i have a 95 302 long block assy. that I am having installed. The new engine has the 351 firing order, what do I have to change to make the new engine work in the truck. I have read that I have to change cams, another said to swap distributors, another answer was to change the plug wires to the standard 302 firing order. Does anybody know the real answer from having done this swap. The shop is ready to change the engine but I am not sure of the right way to make it work.
  #2 (permalink)
Old 11-01-2009, 08:34 PM
greystreak92's Avatar
greystreak92 greystreak92 is online now
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
Welcome to FTE and the Big Bronco Forum.
There is no firing order difference between those two engines. The 302 and 351 got the same firing order when Ford went to the EEC-IV computer control. It simplified the electronics to have both engines with the same firing order. The only potential issue you might run into is the possibility that the 95 is set up for mass air. But I am aware of no differences in long blocks between the two. Wait and let someone who knows for certain tell you whether the cams are different. Kemicalburns or PaulO will be your best bet for a correct answer there.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
Tags
1992 , 302 , 351 , 58 , 93 , bronco , early , engine , engines , f150 , motor , swap , swop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
