Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 04:05 PM
SurpriseF350Sport's Avatar
SurpriseF350Sport SurpriseF350Sport is offline
SurpriseF350Sport is starting off with a positive reputation.
How long does is take to do a spring swap?
I have found a complete suspension with v front springs and p rear springs, with hangers bump stops etc. from an 2004 f250 fx4 to go on my wifes 2005 EX.
Has any of you changed the springs on the garage floor? How long does it take? I think I will change the front first and see what it looks like.
Does anyone have a written procedure?
thanks
Richard
  #2 (permalink)
Old 11-01-2009, 05:17 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Quote:
Nice score!
Does the driveway count?
Depends on how much help you have. I did it with a buddy and it took us around 3 hours or so? It's been a long times since I've done it and I can't remember exactly. Sorry.
thanks
Richard
It's really straightforward, but this link will give you a decent working knowledge that will help. 2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds | SuperMotors.net
I scanned it really quick because I wanted to see if that link instructed to remove the front bumper, to get to the front spring eye bolt, and it doesn't. It instructs you to remove the corner bumper supports instead.
I have no clue how hard that is, but I do know removing the bumper was EXTREMELY EASY. I think it was 4 bolts (maybe 6) and the bumper comes right off, allowing EASY access to the front spring bolt.
I couldn't believe how easy it was to remove the bumper, I'd strongly recommend that procedure over the one listed in the link, simply because I don't see how removing the bumper supports could be easier than removing the bumper, especially when the link say's to use an impact wrench to remove the corner supports.
I did all my stuff with simple hand tools.
Stewart
PS - If you only have one floor jack, borrow another from a buddy. Having two made things easier for me.
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #3 (permalink)
Old 11-01-2009, 05:29 PM
Quote:
Originally Posted by Stewart_H View Post
Nice score!
Yes Absolutley!
Stewart
Thanks a bunch! I have a willing buddy to help, sounds like a good weekend project.
thanks again!
  #4 (permalink)
Old 11-01-2009, 05:49 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
You're welcome.
Hopefully some of the other guys who have done this mod more recently than I have can chime in with help too.
Stewart
__________________
  #5 (permalink)
Old 11-01-2009, 05:52 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
I just did a quick search of my old posts and it's 4 bolts to remove the bumper.
http://www.ford-trucks.com/forums/52...ml#post3908788
Stewart
__________________
  #6 (permalink)
Old 11-01-2009, 06:26 PM
Cool thanks, btw how long does it take to change the rear springs? Easier?
thanks
  #7 (permalink)
Old 11-01-2009, 11:38 PM
X-Hibition's Avatar
X-Hibition X-Hibition is offline
2005 Ford Excursion
X-Hibition is starting off with a positive reputation.
It depends upon the rust...
Rear A/C lines need the support bolts removed and lines moved aside to access right rear hanger bolt.
__________________
2005 Excursion Limited 4x4 PSD with Airaid Intake, KC Light Bar w/four Pro Comp 9911, Yakima Rack w/ four bars, C-Betr, Oilguard Bypass Filter, Jotto Desk, Banks Intercooler, MBRP T-304 Turbo back Exhaust, Icon 5" kit...so far
  #8 (permalink)
Old 11-02-2009, 08:17 PM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz has a good reputation on FTE. wallz has a good reputation on FTE.
Took about 8 hrs by myself, with the 10 yr old as a helper.
The rear will be faster, no bumper to take off. Just remember to take the spring with the spring hanger off together and then put the hanger on your new springs loosely before you mount back up. And as above, the ac lines need to be moved over just a tad to get to the bolts on that side.
__________________
2002 Excursion, 4x4, V-10, some mods, and many more to dream about!
  #9 (permalink)
Old 11-03-2009, 08:39 AM
housedad housedad is online now
housedad is gaining momentum as a positive member of FTE. housedad is gaining momentum as a positive member of FTE.
Working by myself, it took me a good 7 to 8 hours to replace the front and rear springs. This included time to add a leaf in the rear and to cut the straight leaf off as a spacer, changing out the front springhangers, installing a below the bumper front hitch. and putting in some Firestone airbags in the back.
It is a general pain to do it by yourself. Get a friend that knows what a wrench is for, and it will sail right along.
Don't forget to re-torque the bolts after a hundred miles!!
Doing it with a friend has got to be better.
__________________
2005 EXCURSION!! XLT V10 Silver Heated trailer mirrors. Added Hood/window deflector, Firestone airbags/onboard air, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Landyot genIV, Curt front reciever, 4.30 axles, C-Betr mirrors, Factory fogs, door lights, 3 gauges, ashtray(no hook).
  #10 (permalink)
Old 11-03-2009, 08:42 AM
Stewart-
Don't forget that there is two bolts toward the end of the bumper for the side brackets.
__________________
  #11 (permalink)
Old 11-03-2009, 03:07 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Quote:
Originally Posted by housedad View Post
Stewart-
Remember?....LOL! Bion 'ole buddy, I have CRS. Can't Remember Stuff. I'd have to remove my front bumper again just to figure out where the bolts are, much less how many there are! LOL
Stewart
__________________
  #12 (permalink)
Old 11-03-2009, 10:23 PM
Forest Forest is offline
Forest is starting off with a positive reputation.
Stewart--
You are the man when it comes to this upgrade. I'm just about to install my new V,B code springs myself. Front bumper is already off to be painted. Was curious about how to pull out the front bolts. As soon as I do my u/g, I'll post comments. Unfortunately, I don't have any buddies to help on this one. Only daughters with a lot of homework.
__________________
'05 Excursion Limited 4x4 6.0L PSD, V and B code springs, 59,000 miles
SOLD '03 Excursion Limited 4X4 6.0L PSD, at 180,300 miles
Towing Arctic Fox 32D (34', 10,000 lb)
using Hensley Arrow
  #13 (permalink)
Old 11-03-2009, 10:34 PM
Wow thanks for all the info. I have a friend willing to help. I have the V code springs I will install those first and see how it looks. If I go ahead and do the rear will I need to lower the driveshaft bearing and can I use the stock rear spring blocks? I plan to do this saturday and will take before and after measurements and pics.
How many of you re use the u bolts? where can I find all the torque values?
  #14 (permalink)
Old 11-03-2009, 10:38 PM
I bought all new U-bolts and nuts. Not cheap. Eight (8) total U-bolts at about $20 each. But...all hardware will be new after the install.
__________________
using Hensley Arrow
  #15 (permalink)
Old 11-04-2009, 12:36 AM
Stewart- That was good.
Richard - About the U-bolts. A lot of people reuse them and they get by OK, I guess. But I go along with Ford on this one. Ford specs for new bolts and nuts on the axles every time they are changed. They also spec for new spring bolts and nuts.
I also forgot to direct you to the pics fo my v code install.
Excursion V codes and Hitch pictures from trucks photos on webshots
Bion
__________________
Tags
2002 , 2004 , code , excursion , excursions , f150 , f250 , ford , installed , leef , lower , mt , rear , removal , spring , springs , swap , truck , vcode
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
