Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 03:33 PM
cable5 cable5 is offline
cable5 is starting off with a positive reputation.
will not start
I have 1993 ford 7.3 will not start will turn over all i get is smoke coming from under valve covers and lot of it thanks AL any help
  #2 (permalink)
Old 11-01-2009, 05:35 PM
rupejosh's Avatar
rupejosh rupejosh is online now
1994 Ford F-250
rupejosh is starting off with a positive reputation.
well welcome to FTE.
so smoke from under the valve covers?weird.is your exhaust pipe smoking?make sure your getting power to the injection pump first.then make sure your motor is spinning over really good.you might try to hook another car up to the pass. side battery and then turning it over to make sure your getting it turned over good enough.
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #3 (permalink)
Old 11-01-2009, 07:48 PM
positive pressure in crankcase a lot thanks AL
  #4 (permalink)
Old 11-01-2009, 09:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
cable5,
Welcome to FTE and the IDI diesel forum.
Has this engine been running recently?
How many miles are on it?
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 11-02-2009, 07:41 AM
not for 3 years
  #6 (permalink)
Old 11-02-2009, 02:15 PM
f350fan1993 f350fan1993 is offline
f350fan1993 is starting off with a positive reputation.
Quote:
Originally Posted by cable5 View Post
not for 3 years
I know the feeling, mine sat up for six and I'm still working bugs out of it.
  #7 (permalink)
Old 11-02-2009, 07:41 PM
removed rt. head found piston on #4 no rings looks like blow rings out of piston did you ever hear anything like this . thanks AL
  #8 (permalink)
Old 11-03-2009, 10:03 PM
1986 Ford F-250
Never heard of anything like that.
Are you sure they aren't stuck down in the lands?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #9 (permalink)
Old 11-07-2009, 03:45 PM
starmilt starmilt is online now
starmilt is gaining momentum as a positive member of FTE. starmilt is gaining momentum as a positive member of FTE.
I once tore down a rebuilt gas engine that had 4 pistons with no rings, but the rebuilder put it together that way. I don't think there is any way for the rings to come off even when broken.
__________________
absolutely no dodges.
to many fords to list.
one town car.
If it breaks because of my advice
you can keep both halves
  #10 (permalink)
Old 11-07-2009, 07:13 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
I've seen pieces eat their way out, but never an entire ring without severe damage
  #11 (permalink)
Old 11-07-2009, 08:11 PM
1986 Ford F-250
Even if broken into rather small pieces, both the piston and cylinder walls would be trashed before the rings could all work their way out completely.
The compression ring is thicker than the piston to cylinder clearance any way you turn it, even if the piece is only 3/8" long.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #12 (permalink)
Old 11-07-2009, 10:20 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is online now
johnboggs21 is starting off with a positive reputation.
This kinda makes me want to think maybe you possibly have a stuck, or sticking exhaust valve.
__________________
1993 F-250HD 7.3L IDI E4OD
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
  #13 (permalink)
Old 11-08-2009, 11:12 AM
1986 Ford F-250
Just read that again, piston 4 id drivers side second from the front.
And if you only pulled the head, you can't tell if the rings are not there or just stuck back in the piston grooves.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Tags
73 , 93 , f250 , ford , start , truck , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
