Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 03:06 PM
CLStewart144's Avatar
CLStewart144 CLStewart144 is offline
CLStewart144 is starting off with a positive reputation.
I/C Removal ???
Ok.. It's a cloudy day outside and the wife is gone to the mall to do some shopping, so I decided to get under the hood and clean all of the pipes that go to the I/C and make sure everything was sealed tight. I got all the pipes off without a problem, already got the @$%^@ foil off of the pipe and all I have left to do is clean the I/C. My question is what all do I have to remove to get it out?? I pulled the upper rad supports and tilted it back a little just to see if it would clear, but it doesn't look as though it will.. I know someone out there has got a trick or to for removing this thing..
Camera battery is charging right now but when its finished I will post pics of the squeaky clean pipes and boots.. And also a pic of the turbo wheel to you guys to analyze!!
Thanks
  #2 (permalink)
Old 11-01-2009, 03:09 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is online now
Springfield Armory
indyF-350psd is gaining momentum as a positive member of FTE. indyF-350psd is gaining momentum as a positive member of FTE.
you might want to drain the rad to help make it lighter to move and also take off the upper rad hose but you can just lean it forward and fanagle the i/c out from behind it. its a tight squeeze and it also helps to have someone hold the rad forward while you pull out the i/c. you can get it out that way though......
__________________
BILL ----> 2002 F350 7.3L CC LB DUALLY LARIAT 6X6
http://www.roadsidehelpnetwork.info/
  #3 (permalink)
Old 11-01-2009, 03:26 PM
Do you have to pull the fan or the shroud to get it out?
  #4 (permalink)
Old 11-01-2009, 03:32 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
You shouldn't have to pull anything but the cross support above the coolers to get it out. You can leave everything in and just pull the I/C.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #5 (permalink)
Old 11-01-2009, 03:39 PM
jkidd_39's Avatar
jkidd_39 jkidd_39 is offline
jkidd_39 has a good reputation on FTE. jkidd_39 has a good reputation on FTE.
Pry bar and a friend pulling straight up and you can work it outta there.. good luck
__________________
*Andrew*(and bff Owlie)
2002 F-350 CCLB 7.3 255,000 Miles
*** 5" Cannon, 6637, DB's HT Starter, Pete's Cover, EV2's, Zoodad, 6.0IC/TC, CCV Mod, BTS VB, Van Turbo/WW, Casserly 160cc SS, RDP HPX, DP Tuner, 2.5" Lvling Kit, 05 Harley Grill, Ceramic IH Uppipes, In-Tank mods*** Next-Homemade RR, Water Inj.
Destroyed by Ford Mechanics, Resurrected By FTE and Riffraff Performance
  #6 (permalink)
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
Quote:
Yep, that's what I did, and even the 6.0L intercooler (which is bigger) can fit in that space too. Just unbolt the reservoir without disconnecting the hose, move it out of the way, and tilt the radiator forward. The intercooler will slide right out.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #7 (permalink)
Old 11-01-2009, 03:45 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is online now
of Family
beanhead6D5 has a very good reputation on FTE. beanhead6D5 has a very good reputation on FTE. beanhead6D5 has a very good reputation on FTE. beanhead6D5 has a very good reputation on FTE.
Like these guys said,a pry bar on one side will do the trick.
I don't know if it will help but here's what I did with mine.Ford Truck Enthusiasts Forums - beanhead6D5's Album: 6.0 IC mod!
__________________
Brad
PAA MEMBER #71
2001 f-250 CC 4x4 auto 7.3,S&B intake,WW,1.00, 4"turbo bk,HPX,intank mods,
Isspro gauges,cold a/c,OBA,ccv,6.0 IC TC,AIH and EBPV delete,DP turner
1965 F-100 2wd,390,4spd.
  #8 (permalink)
Old 11-01-2009, 04:46 PM
Thanks for the quick reply guys... I just got the I/C out and will be cleaning it after this post.. is there anything else that I should do while i'm this deep in here??
  #9 (permalink)
Old 11-01-2009, 05:53 PM
Springfield Armory
how much you want to spend?
__________________
  #10 (permalink)
Old 11-01-2009, 07:14 PM
of Family
Quote:
Wash out the radiator!Or at least blow it out with air.
__________________
Brad
PAA MEMBER #71
  #11 (permalink)
Old 11-01-2009, 07:44 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
There are 4 bolts on each side, and once they're out, it can still be a PITA to get that cross-member out. I had to really work it to get it out. The AC lines are somewhat in the way, but the outlet will clear with a little shifting of the condenser. Other than that, it's all covered. Now would be be an excellent time for an upgraded trans cooler, but it sounds like you won't have time to wait to buy one & have it shipped...
__________________
  #12 (permalink)
Old 11-01-2009, 09:55 PM
I finally got everything back together... Thanks guys for all your help.. Now I have to get Clay's CCV kit so that I never have to do it again..
Tags
06 , diesel , duty , removal , shroud , super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
