Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 02:38 PM
99SevenPoint3's Avatar
99SevenPoint3 99SevenPoint3 is offline
99SevenPoint3 is starting off with a positive reputation.
dually axle
ok so not to long ago i bought a dually axle from a craigslist add but it came off a cab n chassis truck And the real reason i picked it up knowing it wasnt going to be a direct bolt on was because it was the same gearing and i got it for $100 bucks n i am going to be puttin it on a regular 4dr so i know i have to weld on new mounts but anyone have any tips on how to go about gettin the right measurements ?
__________________
Zeus
_Early 99 7.3L 6spd F350 Dually 8" inch lift w/22.5's ..hpx,ccv,intank, zoodad -H/M k&n kit,SouthBendClutch, 02 turbo/w WW,intank pump club,Bellowed up-pipes,MKO 5" exhaust
_94 7.3L IDI Factory turbo 5spd F350 (some upgrades)
  #2 (permalink)
Old 11-01-2009, 03:52 PM
u.f.o u.f.o is offline
u.f.o is starting off with a positive reputation.
I dont think you can get it too fit , a pickup axle is 4 inchs wider.
  #3 (permalink)
Old 11-01-2009, 06:14 PM
FL-Mudd-Duck's Avatar
FL-Mudd-Duck FL-Mudd-Duck is offline
1985 Ford F-250
FL-Mudd-Duck is starting off with a positive reputation.
dwr cab and chassis and regular srw are same width but have diff spring perch width. non cab and chassis drw are 4 or so inches wider
__________________
85 f-250 6.9 c/6 4x4 d60f/d70r 8 inch superlift 325/85/16 xmls straight pipes with 5" twin stacks soon to be turbofied aka big nasty!
2004 ranger edge 4.0 5r55e ext cab flareside
  #4 (permalink)
Old 11-01-2009, 06:15 PM
well that doesnt sound so good...
__________________
Zeus
  #5 (permalink)
Old 11-01-2009, 06:18 PM
1985 Ford F-250
r u putting it in a drw or srw
__________________
  #6 (permalink)
Old 11-01-2009, 06:40 PM
im trying to put it on a srw truck ...basically converting it to a dually
__________________
Zeus
  #7 (permalink)
Old 11-01-2009, 07:25 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
you will have to move the axle perches. i dont see why you cant make it fit though
__________________
91 F-250 7.3 N/A ZF-5 2wd, 4" ram air, Isspro gauges, IP turned up, 265/75/16 A/Ts, 15% tint, carter p4594 ele pump, 55w back up lights, class V hitch, 4" exhaust w/14" magnaflow diesel muffler, steering stabilizer (DD/hauler)
88 F-250 460 c6 4x4 Lifted on 36" TSL super swampers, stacks, MSD 6al, holley red, warn hubs (Mud truck)
  #8 (permalink)
Old 11-01-2009, 08:03 PM
Chicken_Fried's Avatar
Chicken_Fried Chicken_Fried is offline
Chicken_Fried is starting off with a positive reputation.
Quote:
Quote:
1234567890
__________________
Tearin' down a dirt road Rebel Flag flyin and a coon dog in the back. Truck bed loaded down with beer and a cold on in my lap -- If you got a problem with that you can Kiss My Country A**
  #9 (permalink)
Old 11-01-2009, 10:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
A cab and chassis frame is 34" wide and has 2.5" wide springs.
A SRW frame is 37.5" wide and has 3" wide springs.
Both of the axles are exactly the same width from back plate to back plate, so if you move the spring perches, you will have an axle exacly like you have now.
Dually axles are 4" wider from back plate to back plate, the dually frame is 37.5 wide and uses 3" rear springs.
Sorry, but the cab and chassis axle will not let you run duals on a SRW truck.
SRW axle length is 53.75" backplate to backplate.
Dually axle length is 57.75" back plate to back plate.
Cab and chassis axle is 53.75" backplate to backplate.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #10 (permalink)
Old 11-02-2009, 07:10 AM
hmm well ima have to go measure the axle i have with the numbers im getting ... if im not mistaken when i got the axle i measured it and i think it was longer then what i already had ...
__________________
Zeus
  #11 (permalink)
Old 11-03-2009, 09:51 PM
1986 Ford F-250
When you measure, the backplates have some high and low places.
Make sure you are in the same location on both axles.
And as usual, CRS is acting up, don't remember if my measurements were on high spots or low spots for sure, but I think high for some reason.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #12 (permalink)
Old 11-03-2009, 10:04 PM
well i went to measure the other day i cant remember the exact measurements but the axle i bought measures out longer then my axle i have now
__________________
Zeus
Tags
2657516 , 8 , axle , axles , dual , duallie , dually , f350 , length , lift , lifted , measurements , stacks , trucks , wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
