Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 01:48 PM
MYBOYDAVE MYBOYDAVE is offline
MYBOYDAVE is starting off with a positive reputation.
VACUUUUM LEAK/CHECK
COULD ANYONE TELL ME IF THERE IS AN EASY WAY TO CHECK TO SEE IF YOU HAVE A VACUUM LEAK
I HAVE A 1989 E-250 VAN 302 FUEL INJECTED
MY IDLE IS HIGH AND I THINK THATS THE PROBLEM
  #2 (permalink)
Old 11-01-2009, 05:02 PM
maples01 maples01 is offline
maples01 is gaining momentum as a positive member of FTE.
There are a couple of hard plastic lines that dry and crack, usually running to cruise, AC, and heater controls, but I suspect yours being the throttle position sensor.
__________________
larets bitch
  #3 (permalink)
Old 11-01-2009, 05:52 PM
DO YOU THINK I SHOULD REPLACE THE THROTTLE POSOTION SENSOR FIRST .
IS THERE A WAY TO CHECK IF ITS BAD
THANKS FOR YOU HELP[
  #4 (permalink)
Old 11-01-2009, 07:02 PM
You can check it with a volt-meter, I can't recall the directions for it, but should be easy to find on the net in a search.
__________________
larets bitch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
