Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 12:49 PM
madpogue madpogue is offline
madpogue is starting off with a positive reputation.
Quick! What size bolt for front shock?
'95 F-250 PSD 4x4 ECLB, 5-speed, 64,000-ish miles
Got some Bilsteins to install. Lower bolts on both front shocks are seized. The nuts will turn right off, but the bolts have fused to the steel inner sleeve within the bushing of the end of the shock. I can turn the bolt head, but I feel it "springing" back, meaning the rubber bushing is twisting.
Been anointing it with PB-Blaster, and took a few light smacks (with the nut in place) at the end of the bolt. But I'm probably looking at cutting the head off the bolt and getting a fresh bolt & nut. Question is - what size? It's an odd combination, head-wise. Bolt head is 22mm, nut is 18. And they're most decidedly metric. Anybody know what would be a good size replacement? Grade 5 (or its metric equivalent), I presume?
Or, any other tricks for getting the buggers out?
TIA.
  #2 (permalink)
Old 11-01-2009, 04:44 PM
Disregard. It's done. 3-lb sledge. I just had to be gentle, keep the nut on for a while and make sure I hadn't damaged the end of the bolt. Used a punch when the end of the bolt got into the bracket. Four new shocks are in.
Tags
05 , 2003 , 99 , bolt , bolts , bushing , bushings , f150 , f250 , ford , front , lower , shock , size , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
