anyway it was a c4 in it, which I have never worked with.
There are the two pipes that are used for the tranny cooler pass side, and there is one pipe that looks like it goes to the top pass side, almost near the starter.
When I bought the truck and they shut it down there was ATF leaking from that pipe.
Any idea what it goes to?
Does the C4 have a vacuum modulator like the C6? Those can leak, and if the tube is hanging instead of being connected to the carb or manifold, it will leak there, and shifting will be at higher rpms and a hard shift, iirc.
I think the tube you're describing is a vent. Does it point down? If so, it could have been over-filled or the trans may be toast and it's overheating and puking fluid out.
