Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 12:09 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Exclamation Drive shaft work + stupidity = 2 broken bones
OK. I'm the one who was stupid... and I'm the one with the left leg propped up with both bones broken above the ankle, waiting for the orthopedic specialist to determine Monday/Tueday if I'll need surgery.
History.... Drive line vibration at 46-49 mph only under load, new center bearing, two new u-joints, and the rear drive shaft piece possibly installed 180 degrees out of phase (or needing the center bearing shim pack).
What happened... Saturday morning, by myself, I went to break loose the rear drive shaft to rotate it 180 to see if that would completely resolve my remaining vibration issue after the center bearing and u-joint had corrected msot of it. When I broke the front joint loose behind the center bearing, the truck started rolling, pulling me with it since I was on my creeper. My head was towards the rear axle and my feet were towards the egnine compartment, with me being on the passenger side of the drive line right underneath the exhaust pipe. I got the truck stopped mmentarily and tried to "toss" a jack stand in front of the rear wheel (it just happened to be under the truck with me to support the drive shaft as I lowered it down). Nope... it didn't go far enough.
No one else nearby.
Cell phone on a saw horse in the garage.
And I could see that if I just let the truck go and rode with it that it might easily jump off the driveway and either into a tree or my neighbors brick house.
Believe me, I was pushing back on the truck with my feet planted, holding it firm, but I couldn't hold it for long. I then decided to let the truck go sloooowly, with me slowing it down, but my left knee slipped up between the drive shaft and the exhaust pipe as the truck pushed me along on the creeper, past my left ankle which was being held firmly on the ground by the truck's weight, and as I went past my left foot, my left leg was essentially rolled up and over my left ankle until the ankle gave way.
I felt the bones give way, but it didn't hurt as much as it scared me because I knew how bad it could have been. I dragged myself into the garage, phoned a neighbor and my wife, and went to the ER. Yep... inside bone broken right above the ankle joint, and the outside bone broken about 6 inches higher up.
Word of advice... ALWAYS chock your wheels and/or use the e-brake when doing drive line work on a vehicle that is still on the ground.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #2 (permalink)
Old 11-01-2009, 12:17 PM
mndiesel's Avatar
mndiesel mndiesel is offline
USAF 84-90
1999 Ford F-250
mndiesel has a good reputation on FTE. mndiesel has a good reputation on FTE. mndiesel has a good reputation on FTE.
Glad to hear your OK it could have been much worst, Let us know about the surgery.
__________________
Tom 99.5 f-250 7.3 sd ec, 4x4 many mods
Minnesota Chapter Leader
Join the MN chapter Here
Join the Roadside help Network
  #3 (permalink)
Old 11-01-2009, 12:20 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Pete,
I am so sorry this happened to you.
I hurt just reading this.
Hope surgery will not be needed.
I've got my fingers crossed for you.
You are one hell of a guy to post this so that others can avoid any harm to themselves.
Take Care, and I hope you heal fast.
  #4 (permalink)
Old 11-01-2009, 12:25 PM
mechelement's Avatar
mechelement mechelement is online now
mechelement is gaining momentum as a positive member of FTE.
That is insane!!! Glad you're OK though.
My left wrist had a compound fracture (bone out of skin) and my left elbow broke at the same time. Surgery was a must. I cannot stress physical therapy enough. Do it. Do it to the extreme. If they offer another course to go to even though the major stuff is finished, do it. I didn't and lost motion in my left elbow.
__________________
Jason
2000 F350 XLT PSD CC 6-sp SRW 4x4
6637
  #5 (permalink)
Old 11-01-2009, 01:04 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
I am glad that it is not worse than it is Pete. I give you credit, like Robin, for posting this as a warning for all to read. I wish that I was closer in order to help you out.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #6 (permalink)
Old 11-01-2009, 01:09 PM
allis327's Avatar
allis327 allis327 is offline
allis327 is starting off with a positive reputation.
SO sorry to hear that. I hope u dont need surgery, hope u get heeled up soon.
__________________
2002 f350 superduty crewcab long box 4x4
6637 w/ pete's cover, 4" turbo back exhaust, zoodad, dipricol optix guages, warn premium lockouts, ccv mod, foil delete, Tru-cool tranny cooler
91f150 4x4 I6
  #7 (permalink)
Old 11-01-2009, 01:10 PM
Ford79's Avatar
Ford79 Ford79 is offline
2001 Ford F-350
Ford79 has a good reputation on FTE. Ford79 has a good reputation on FTE. Ford79 has a good reputation on FTE.
Pete, hopefully surgery isn't needed and you recover quickly. That is a VERY good reminder about the chocks/parking brake.
__________________
Mike
2001 F350 CC LB 7.3 with a few mods
Wisconsin Chapter Leader JOIN HERE
7.3 Roadside Help Network
  #8 (permalink)
Old 11-01-2009, 01:23 PM
87 F-150 I6's Avatar
87 F-150 I6 87 F-150 I6 is offline
Duct tape and a hammer!
87 F-150 I6 has a good reputation on FTE. 87 F-150 I6 has a good reputation on FTE.
Pete, glad your still with us! Hope you wont need surgery and have a quick recovery.
__________________
Andrew
2002 F-250 7.3L 4X4 CC SB AT /6637 mod/SS HPX/Stancore GPR/5" MBRP exhaust/Foil Delete/
  #9 (permalink)
Old 11-01-2009, 01:26 PM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
HOLY CRAP!! What a story!! I guess it's the military side of me, but whenever I work on the truck, I always chock the wheels. We have to in the big military trucks every time we park them.
Sorry this happened to you -- and glad you posted it. Hopefully it helps someone else out.
__________________
  #10 (permalink)
Old 11-01-2009, 01:39 PM
maevans's Avatar
maevans maevans is online now
<--Michigan GTG
maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE.
WOW....... that is scary to hear.
I wish you a speedy recovery Pete.
__________________
MARK
EARLY 99 PSD.
MICHIGAN CHAPTER
ROADSIDE HELP MEMBER
Pics and Mods in Gallery.
Have a Great day........
  #11 (permalink)
Old 11-01-2009, 01:51 PM
truckeemtnfords truckeemtnfords is offline
RHN................
truckeemtnfords is gaining momentum as a positive member of FTE.
Hope you get healed up quickly, broken bones and winter don't go good together.
__________________
Dave
2002 F-250 XLT 4x4 7.3 Auto CC LB
1955 F-100 302 T-5 9"
  #12 (permalink)
Old 11-01-2009, 01:54 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Sorry to hear this Pete. Hopefully you're story will serve as a reminder to someone in the future and prevent a similar injury. I'm glad to hear things did not turn out even worse.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #13 (permalink)
Old 11-01-2009, 02:04 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Not many men get to tell a story like that. Good luck in your recovery.
The other story I've seen--someone else telling it--is about pulling the driveshaft on rig with a trans-mounted e-brake.
Wheel chocks are your friends.....
  #14 (permalink)
Old 11-01-2009, 02:15 PM
F250_'s Avatar
2002 Ford F-250
Thanks guys. I'm very, very grateful forhow things worked out so far. My neighbor and my 17 yo climbed back under the truck and reconnected the shaft for me yesterday, too.
Here's just another example of how good my God was to me in this situation... one of the u-joint cup bearings gt dragged off, and several needle bearings were missing when we discovered it. Thankfully, we found every single needle bearing and was able to just clean them off, re-insert them into the cup housing, re-install the cup, and then reconnect everything. And yes, they did get the shaft rotated the 180 degrees, too.
Once I can drive it again, I'll get to see if that resolves the vibration. If not, then the center bearing shims will be a snap to install... and I WILL be using both the e-brake and the wheel chocks before I crawl under there again!
Also, I'm very grateful that I was on the creeper to begin with so that I could get carried along with the truck instead of squished between the driveway and the rear axle!
__________________
  #15 (permalink)
Old 11-01-2009, 02:28 PM
Smokin''s Avatar
Smokin' Smokin' is online now
Smith & Wesson
1999 Ford F-250
Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of
Pete! What a story. I'm glad you escaped with just a broken ankle, and not worse. Even though what you went through sounds scary and painful, sounds like you kept your head about you even with all of this going on. A bit terrifying when things happen and you are all by yourself.
Speedy recovery, let us know if you need anything.
__________________
Lisa Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Hypermax Boost Pyrometer, 4" exhaust, DP Tunes - no start, 60 Tow, 80 Econo, 120 Race, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, oil crossover Kit.
Tags
2001 , clicking , drive , driveline , driveshaft , f250 , ford , harm , length , list , lowered , piece , rear , shaft , truck , vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
