Thank you for having the guts to share the mistake you made, it is not always easy to do so, but you may have saved someones leg, or even their life by sharing like this.
I know a guy who was under a truck, and the old POS somehow fell into reverse, and it drove off the ramps it was on, narrowly missing his head, and then continued reversing right out of the closed shop door and hit a dividing wall.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
I nipped the end of my little finger using a jointer last summer, don't be too hard on yourelf, mistakes are made, those that don't kill you make you careful again. I wish you well in your recovery.
__________________
Don
2003 F250 SD,C/CSB, 444 PSD, Auto, 4x4, xlt, Lariat
Edge juice with attitude, Factory Tech vb, 4" turbo back, Muffler delete, Fog light mod, Rough Country dual steering stabilizer, Rear Air Lift bags, Front shackle lift, more to come, funds permitting.
Dang the bad luck just glad your ok. As said thanks for sharing and a speedy recovery
__________________ Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
I appreciate the well-wishes and offers to help where possible. All things being the way they are, I'm in pretty good shape right now and the family and neighbors are doing a great job of keeping me in line and off my feet (for the time being).
As much as I feel sort of stupid for not having thought through the potential ahead of time, I've always tried to look on mistakes as being a sort of "tough love" friends in that they do (hopefully) teach valuable lessons when we choose to take those lessons to heart. I'm also convinced that they offer us opportunities to provide experiential guidance and insights to help others avoid the same msitakes (especially our children!).
I never mentioned what ended up happening with the truck... I guess it was partially due to the resistance of manuevering my knee and leg that helped it just settle in the low spot in the driveway. So, it landed exactly where i wanted it to, and even provided more clearance for my son and neighbor to do the reconnect than had it been anywhere else in the driveway. God is SO good.
Man Pete, we know you are a beast, you didn't have to try and benchpress the whole truck to prove it, LOL. Really glad you are ok, and are prayers will be with you for a speedy recovery.
At what point and time did you try and bench press the truck off yourself???I know I would of tryed to.
Get better quick BRO.
__________________
Brad PAA MEMBER #71
2001 f-250 CC 4x4 auto 7.3,S&B intake,WW,1.00, 4"turbo bk,HPX,intank mods,
Isspro gauges,cold a/c,OBA,ccv,6.0 IC TC,AIH and EBPV delete,DP turner
I appreciate the well-wishes and offers to help where possible. All things being the way they are, I'm in pretty good shape right now and the family and neighbors are doing a great job of keeping me in line and off my feet (for the time being). PMS won't keep you down for long.
Amen to that.
I should apologize now Pete. About a month / three weeks ago I took the rear drive shaft off to grease the slip joint. This same thing (almost) happened. I couldn't get the drive shaft off so I gave it a tap with a hammer when it gave loose the truck started to roll . It stopped within six inches of hitting the down hill slope of my drive way. I layed there on the ground no creepy making sure that the truck didn't want to roll anymore before I tried to roll out from under it. Luckily I was able to get out and chock the tire before anything happened. I have always been careful working on vehicles. I have always chocked a tire and for some reason didn't this time.
So don't feel alone. I wish you a fast and painless recovery. Isn't our God great!!!
__________________ Thank you to all the Military ,Police, and Fire for what you do for our country.
Jody PAA MEMBER #93 2001 Ford F-250 CC 4X4 Lariat 7.3
93,000 "Almost Broken In"
6637 W/ Pete's Cover, CCV, more Mods coming soon.
I too was cringing, watching in my minds eye as you described what happened.
Ouch dude, ouch.
So damn glad it wasn't worse tho buddy.
Quote:
Originally Posted by F250_
...how good my God was to me in this situation...
God is SO good.
Amen brother, amen.
Quote:
Once I can drive it again, I'll get to see if that resolves the vibration.
You drive with your right leg, bro!
Stewart
__________________ The Brotherhood of FTE <~click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody 2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
A good lesson learned for the rest of us.... I have never been one to crawl under my truck for anything without the e brake set and the tires chalked...
__________________ Nolan
2001*F250*Ext.Cab*LB*4x4*6spd
4"turbo back exhaust, 6637w/custom Pete cover, Gooseneck hitch, Cobra148GTL w/102" whip PAA #64
Can't add to much to what everyone else said. I did the same thing when I disconnected my drive shaft. Luckily, I was on a very little incline and was able to put a hammer under the front wheel and stopped the truck. Safety should always be the first thought when you take on any project. Sometimes easily overlooked. Now I wish I would of posted up what I did. Hope all goes good for you.....
__________________
2000 7.3 powerstroke. Bull dog tuner. Air raid cold air intake. AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. Walker 21470 muffler.
