I am replacing the pads on my 2004 F-250 6.0 and for the life of me I cannot get the discs off. The Haynes manuel says to remove the caliper and the disc should just come off. What am I missing?
Dave
loosen the parking brake adjustment nut, its probally a little to tight, remember to tighten it when your all done
__________________
04 F-350 SC, SB, 4x4, V8, Auto, 4.30 gears,
K&N intake with pre wrap, 1714 Super Chip programmer, Gibson SS headers, e-bay y-pipe, high flow converter, pro chamber muffler, custom add a leaf, dually camper leaf
1978 F-150 4x4 351M stock for now (my new hunting rig)
What happens is you get dirt and and other junk that builds up between the rotor and the hub. My rears have at time looked like they were a one piece hub/rotor. Lot's of effort to get the things off. It was especially bad when I lived up North with the salt. I have even used a dremel tool to grind out the junk that had built up between the two combined with a the BFH.
Try beating them off with a rubber mallet. I know in Ohio here, mine were basically rusted together. Resurface them while you are at it, and make sure you properly bed them in. Makes a good bit of difference.
__________________ 2002 F-250 - V10, Crew Cab, Short Bed, Lariat 4x4 aka My Lovely Big Girl.
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
Get two heavy duty large bolts (long enough to apply even pressure) with nuts. You will also need a piece of heavy gauge plastic or hard wood that won't allow the bolts to damage the rotors. Put the two bolts through the caliper mounting holes nut and (maybe large washer) inside, whith bolt head on outside. Now begin by evenly tightening both bolts againt rotor...once tight...tap easily with mall or large hammer....tighten bolts some more (evenly)...tap...tap...tap...tighten...tighten...t ighten...you get the idea...just about the only way to get them off and still salvage the rotors. Good luck.
