Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 10:50 AM
YoungFordAddict66 YoungFordAddict66 is offline
YoungFordAddict66 is starting off with a positive reputation.
My new baby
As of a tuesday i am the proud owner of a 95 F250 Xl PSD 4X4 longed, after previously driving a 78 f250 4X4 with a 400 for the last 3 yrs. it is in need of new tires before the winter and was thinking before i put new tires on her i would like to lift it 4 inches and then put some bigger rubber on her to start the transfermation. so my question is do these trucks usually have 4.10's and if so what is the biggest tire i can run on 4.10's before i have to go to something bigger like 4.55's or so. i would like to put 35's under her. thanks
__________________
Blake
Pardon me chevy. Excuse me dodge! Ahhh just get the hell out my way before i run you both over!
1978 F-250 supercab, 400m, 4X4, 650 Edelbrock, Cherry Bombs, Headers
My new baby 1995 Powerstroke supercab, 4X4, Garret Turbo
  #2 (permalink)
Old 11-01-2009, 10:55 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg is starting off with a positive reputation.
Congrats on the upgrade!!! Welcome to your next chapter in Ford truck ownership! I don't know much about the tire question you have but I want to share a cool site with you.Tips - Idea - Hints See you around!
__________________
97 F350 7.3L Auto 4WD Crew Cab 200K (Cali model bummer). Another OFFICIAL six point slow recovery vehicle! MODS: HOOOOGA! horn, PO MAN's air intake, Service/Utility bed, 3" DP, Testing that Cat, 120v IDM, 2 10K pots. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF. To ALL that have served, THANK YOU!
  #3 (permalink)
Old 11-01-2009, 11:25 AM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
X2 on the new truck. Some trucks came with 3.55 and others came with 4.10. If you are running 70 mph and the tach reads about 1900rpm then you have 3.55. If your tach reads 2500rpm you have 4.10. You can run 35 inch tires without problems with either gear. These trucks make a lot of power down low. You just need to make some simple mods to help it out. 3inch downpipe and free flowing exhaust. IE lose the kitty and muffler or get a less restrictive muffler. Free up the intake with the 6637 mod.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #4 (permalink)
Old 11-01-2009, 11:28 AM
Copedawg's Avatar
I Agree! DP and air 1st these are the "gateway" mods. Then maybe the 10K That ought get you going in the right direction a lot quicker and faster.
__________________
  #5 (permalink)
Old 11-01-2009, 12:08 PM
rideracelivemx7 rideracelivemx7 is online now
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
have fun lifting that pig, the D50 front end is a bitch to get level and the toe angle right, you have to do a shackle lift for the front, it was a never ending battle when i did my leaf springs, it was an inch to high and it chewed my tires, just going around the block and back.but congrats on the truck! i have the same truck just xlt, get us some pics!
__________________
red 7.3 powerstroke diesel-6637-10k-6 POS chip big name tunes-HPX line-3" Downpipe--> 6" Aussie stacks! 3:55s auto-122k miles-Rotella Synthetic, ebpv butterfly removed
  #6 (permalink)
Old 11-01-2009, 12:38 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
1996 Ford F-250
cowmilker08 is starting off with a positive reputation.
Swap to D60 if you're gonna lift it.
__________________
Phil
1996 F-250HD
"Wake up and smell the scent of a Powerstroke starting on a cold, snowy morning!"
  #7 (permalink)
Old 11-01-2009, 07:06 PM
Quote:
ok a question on the rpm's u stated is that with or without OD on? and whats a 6637 mod? and i am thinking of putting new exuast on it i have 4 inch and bigger at my house that just needs to be bent and i am looking at getting the 3" dp to help the turbo.
__________________
Blake
  #8 (permalink)
Old 11-01-2009, 07:44 PM
95_Dually's Avatar
1995 Ford F-350
That is in OD.
The 6637 mod is a napa 6637 air filter. Remove the factory air cleaner. Get a 4inch 45* pipe and insert it into the factory rubber hose that used to connect to the factory airbox. The 6637 filter will slip over the end of the 4inch pipe and secure it with a new worm clamp. I do not have any pictures, but somebody else may chime in with some.
__________________
Sam
  #9 (permalink)
Old 11-01-2009, 07:51 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
the dana 50 is just fine! no shackle mods! get a good lift kit and you will be fine, dont get the junk pivot bracket, get a heavy duty one. i posted picks in your other topic. skyjacker is the way to go with the lift kit for your truck. with the proper lift kit getting the front end aligned is no concern. i put 70k on my last set of bfg mudterrains, 35k on my next set of all terrains(wore out fast but even) and my current tires are 36 inch goodyear mt military tires, and i have a 6 inch lift. do not fear the dana 50. it is a solid rugged and dependable axle
also, i have 4.10's in my truck and the 35's are like driving the truck on stock tires and 3.55 gears. the 36's feel no different. i had 38.5 superswampers on it for about a month and they took some horsepower away.
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #10 (permalink)
Old 11-01-2009, 09:28 PM
95_Dually's Avatar
1995 Ford F-350
Here is a picture. This is on my truck.
__________________
Sam
  #11 (permalink)
Old 11-01-2009, 09:41 PM
wow, your filter is white.....i forgot thats what they are supposed to look like. i need to get a new one
__________________
  #12 (permalink)
Old 11-01-2009, 09:50 PM
95_Dually's Avatar
1995 Ford F-350
Quote:
I hope it stays like that a long long time!
__________________
Sam
  #13 (permalink)
Old 11-02-2009, 12:13 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is gaining momentum as a positive member of FTE.
Youngford, congrats on the new truck!! hope you enjoy it and enjoy modding like we do b/c we can damage your wallet if you don't watch it!! LoL. the 6637 intake, 3" downpipe to 4" exhaust will help ya out a bit. my truck has 3.55's with a 5 speed and it runs probably around 2k rpm around 68mph. it seems that my truck runs different rpms than most ppls but i'm not sure why that would be. haha. just look at your axle code on the sticker then figure out what rear diff you got from there or look at the tag on the rear end and it will say what it has. i gotta try to find the link to the axle code chart now. you won't have any problems running 35's though either way. if you have an auto there are some mods i would look into doing to the auto especially with the larger tires. i know Joe knows his stuff on the autos and lifts and what not on these things so he can probably tell you a lot on that subject.
95_Dually, i need me a new filter now after seeing yours!!! thanx for helping me spend another $40 on it!! haha. i will have to look into skyjacker now for the f150... LoL
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #14 (permalink)
Old 11-02-2009, 02:42 AM
Oversize's Avatar
Oversize Oversize is offline
1996 Ford F-250
Oversize is gaining momentum as a positive member of FTE.
Maybe this will help you understand your gearing vs tire size.
4Lo.com :: Gear Ratio & Tire Size Chart
__________________
96 F-250 HD, SC, LB, 7.3 DI Diesel, 5 spd, 6" lift, 35" AT's, 3" DP, cat gut, 6" straight pipe, 4.10's, FPR shim, custom intake, Hot pedal, HPX, Pyro, Boost, ...
Professional driver, Former CAT and Industrial Mech, P/T race engineer.
  #15 (permalink)
Old 11-02-2009, 02:50 AM
95_Dually's Avatar
1995 Ford F-350
Sorry Travis. I didn't mean for you to spend money like that.LOL
__________________
Sam
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
