Thanks for the link Oversize. Tried to rep you but.....................
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <>< 95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v 2000 Ranger 4X4 No MODS, yet!
ok so does this air filter come with the 4 inch pipe and clamp or do i have to find a clamp and bend some pipe i have that i was going to use for exuast. and how much does it cost? and how much does it help?
__________________
Pardon me chevy. Excuse me dodge! Ahhh just get the hell out my way before i run you both over!
1978 F-250 supercab, 400m, 4X4, 650 Edelbrock, Cherry Bombs, Headers
My new baby 1995 Powerstroke supercab, 4X4, Garret Turbo
You buy the pipe seperatly from the filter. I just used a 45* 4" PVC pipe from my local hardware store and it is working just fine, it was supposed to be temporary but you know how that **** goes haha. I would just buy the bent up 45* so you can use the rest of your stock for the exhaust, it's a relatively cheap piece and the filter is cheapest from fleetfilters.com.
ok a question on the rpm's u stated is that with or without OD on? and whats a 6637 mod? and i am thinking of putting new exuast on it i have 4 inch and bigger at my house that just needs to be bent and i am looking at getting the 3" dp to help the turbo.
not very many shops can bend 4" tubing. Exhaust dies for benders only go up to 3" and its a whole other machine for larger pipe. Kits aren't terribly expensive though.
With the 45* PVC pipe did you have to add any length to it so that the filter is placed out of the way? I have done a similar mod on another engine but it was kinda totally different and am hoping to avoid a bunch of trips to the hardware store. Thanks for all the help. Where would I look for info on mid to high rpm missing/whitish blue smoke...
start a thread about it. gives us the info on the truck and exactly what it's doing. more people will see it this way and will be able to give you some insight on it. almost sounds like injector o-rings though. start a thread and go from there
I made mine using exhaust tubing. I bought a 90* elbow and 2 feet of pipe. I have enough left over to make a 2nd one for a buddy of mine. It was probably more expensive for me to make this than it needed to be. I spent about 100.00 in parts. LOL
Napa is NOT the cheapest place to purchase stuff.LOL
__________________
Sam
ok well the dp is a must and will be coming soon. so can i just go to any hardware store and buy this 4inch 45 degree steel pipe or what do i have to do to obtain it?
__________________
You can try the hardware store. Get the filter first so you can test fit the pipe. You might try a big truck supply store or someplace that sells 4inch pipe. I bought mine from NAPA because it was easy and they had the parts in stock.
__________________
Sam
ok thanks i'll get that put together as soon as i can. here's another question dor anyone whats the ideal size for exuast tubing i should go. my truck is stock right now and dont know whats to big to run the full length of the truck?
__________________
I like 4inch. Others have installed 5 inch. Still others like stacks. If I were you, I would look at some trucks that have already been done so you can get an idea of what you like.
__________________
Sam
I did the 6637 mod today with a 45* 4" black PVC elbow. Kinda of a big a.. filter. I didn't notice much differance over what the stock set up but I think that is due to the dp being stock. I found a used dp for 20 bones so I will do the ebpv mod tomorrow and install the dp. Should be interesting. Anyone near Spokane Wa?
The air filter mod compliments the exhaust mod by allowing more air in after the exhaust is opened up.
__________________
Sam
