Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 10:38 AM
jakescars jakescars is offline
jakescars is starting off with a positive reputation.
Cool I like it hot but not that hot! (GPR Issue)
I know that there is alot of talk of gpr issues and hard starts on here, however I can't seem to find mine.
My 01 f350 has had a bad current draw to the point of dropping down to around 9 volts while driving at 1800 rpms (dvm wired direct to charging post of alternator so I can monitor while driving). The gpr has 12 volts constant to input side and zero to the output with key off. Once key on output also has 12 volts as well does the s terminal(closest to front of truck).
After about 15 -20 minutes of warm up and even a short drive the gpr still has 12 volts on both main big lugs and they are hotter than #^#*. I did read that after warm up that you should have 12 v on the input and 12 v on both small posts, I have 12 v on input, output, and the frnt small terminal and only 6.85 v on the other small terminal(" I "terminal I believe).
What is telling this relay to stay open constantly. BTW this is the second relay I have tried in 2 weeks so I am pretty certain it has nothing to do with the problem.
  #2 (permalink)
Old 11-01-2009, 10:53 AM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
The GPR get it's signal from the PCM. FOr some reason the PCM is telling it to stay on. I'm not to sure if an AE will scan for issues like that though. A quick and simple fix is to put a switch in line and manually control the GPR. The added "run time" I would imagine is decreasing the life expectancy of the GP's as well.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #3 (permalink)
Old 11-01-2009, 12:33 PM
Thanks Jim I just used my Hypertech tuner to check for Dtc's and came up with P0380 which tells me nothing other than a gp ciruit fault.
  #4 (permalink)
Old 11-01-2009, 12:44 PM
megawatt00's Avatar
Quote:
The Ford Code says fault on Ckt A
P0380 Glow Plug Circuit Error Circuit A
That may be GPM specific though. Maybe someone with an AE will chime in. I just got one and haven't started to "play" with it yet.
__________________
Jim
2001 F350 4X4 DRW
PAA # 14
  #5 (permalink)
Old 11-01-2009, 01:20 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
I would disconnect the GPR (small control lines) and tape up the wiring until you can figure it out. You don't want them running all the time. That's very strange and I'm curious what the issue will end up being. It could be as simple as the PCM not sensing that it's on. Check the wiring really well to make sure it's where it's supposed to be and not broken or shorting out.
__________________
  #6 (permalink)
Old 11-01-2009, 01:36 PM
Izzy351 are you talking the two small terminal wires on the gpr? This is my everyday driver and I live where the snow flies, this will make it difficult to start the truck correct? Would I still be able to jump the relay with a screwdriver with these disconnected?
Thanks for you all's help
Don
  #7 (permalink)
Old 11-01-2009, 02:26 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is gaining momentum as a positive member of FTE. tdpower is gaining momentum as a positive member of FTE.
Are you sure that you have a glow plug relay and not a gpcm? There is also a AIH relay in front of the glow plug relay. Just making sure you are not measuring the AIH relay. That would make more sense for that one to stay on longer when cold. You might consider a switch like Jim mentioned. I would use a push button one so it would not stay activated accidentally. The pcm sends a ground to the GPR to activate it. So if you did that you would want to disconnect the wire from the pcm to gpr and wire from ground to the switch and then to the gpr. I'm not sure which little post it is but here is a wiring diagram: http://www.thedieselstop.com/faq/949...Econoline1.pdf
A lot of people do an AIH delete: http://www.dieselsite.com/index.asp?...PROD&ProdID=48
__________________
2000 7.3 powerstroke. Bull dog tuner. Air raid cold air intake. AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. Walker 21470 muffler.
Grant
  #8 (permalink)
Old 11-01-2009, 02:42 PM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
I wonder if its an Air intake heater problem?
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #9 (permalink)
Old 11-01-2009, 04:22 PM
hucka1a's Avatar
hucka1a hucka1a is online now
Welcome Home 776th!!!
hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE.
I would do like Jim suggested and run it through a switch until you can track down the culprit.
__________________
Huck PAA Member 66, E.T.A.P.S. Member
early 99 (11/24/98) F250, PSD, auto, 4x4, ec, short bed.6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats(Thanks Scott), PMT2, Transgo Tugger, DP Tuner F6, diy oba, Isspro Performax, pyro, boost,Trans temp, and EOT mueckster 710 cap,True-Trac(Thanks Cory),diy Coolant filter.Riffraff Diesel Pete's Covers DP-Tuner Roadside Help Network
  #10 (permalink)
Old 11-01-2009, 06:09 PM
danskool's Avatar
danskool danskool is offline
Got temporary coach.
danskool has a great reputation on FTE. danskool has a great reputation on FTE. danskool has a great reputation on FTE. danskool has a great reputation on FTE.
I wonder if the relay just sticks. From all the arching and the spring isn't enough force to unstuck it.. They get pretty burnt on the inside of the factory relay and the contacts could fuse. I put in three Napa relays (Them relays are junk)in one summer before i found out about the stancor. . You also might want to ohmm out your GP's encase one or a couple are shorted.
__________________
Dan
2001 F250 XLT 7.3 PSD 2wd Auto 86k miles
Foil Delete. In tank fuel mod. TC Lockup & EBPV Brake. CCK. 50c Mod. Stancor GPR, LL delete, 6637/wpete, Stock muffler delete w/summit pass thru muffler.. FPR shim 65psi. Radiator hose wrap around. RV plug relocate to bed.
  #11 (permalink)
Old 11-01-2009, 07:45 PM
It is a gpr and not a gpcm. I thought about disconnecting the gpr and using the AIH relay in its place just to check.
Just a bit more info: when the original OEM relay bit the dust a year ago I grabbed one from Checkers ($60) and it worked fine all this time then about 2 weeks ago I had a hard start and decided to try jumping the relay and the truck fired right up, I went and got checkers to warranty the relay so I put in the new one and all this began. Last nite I took that
relay and went and warrantied it also and the same problem, this is why I don't believe it to be the relay or could it.
The guys at checkers told me that they just started getting these from a different company and they are suppose to be better but I am begining to wonder.
Thanks guys!
  #12 (permalink)
Old 11-01-2009, 07:49 PM
One more question. If the pcm is controlling when the relay should work or not what determines that. Hope that makes sense
  #13 (permalink)
Old 11-01-2009, 09:00 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is online now
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Engine oil temp will determine how long the GPR stays operated. You may just have a bad EOT sensor. The proper scanner, like AE, can monitor oil temp.
  #14 (permalink)
Old 11-06-2009, 09:06 AM
just an update! Well we got the whole system scanned and tested and found nothing other than code P0380 again. The problem seems to have changed a bit in that sometimes now we cannot get the circuit to complete to fire the glowplugs but if we ground the pcm post on the gpr then they will fire and stay constant untill we shut the truck off. I am going to test to make sure that I have no issues between the pcm post of the relay and the 101 pin on the pcm harness.
In the event that the harness is good to go I seems that I am looking at a new pcm, whats everyone think?
Thanks
Don
  #15 (permalink)
Old 11-06-2009, 09:10 AM
megawatt00's Avatar
That what it seems like to me Don. The output on the PCM is erratic.
__________________
Jim
2001 F350 4X4 DRW
PAA # 14
Tags
97 , aih , code , diesel , f350 , ford , glow , gpr , hot , pcm , plug , po380 , relay , switch , terminals , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
