Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-06-2009, 09:28 AM
jakescars jakescars is offline
jakescars is starting off with a positive reputation.
Does the pcm have to be programmed if replaced or is it just a plug and play?
  #17 (permalink)
Old 11-06-2009, 10:12 AM
tdpower's Avatar
tdpower tdpower is offline
tdpower is gaining momentum as a positive member of FTE. tdpower is gaining momentum as a positive member of FTE.
You should not have to program the pcm but want to make sure that the code on the pcm matches up. Also, you might try to unplug the eot sensor and turn on the key. This is suppose to energize the glow plugs for two minutes.
__________________
2000 7.3 powerstroke. Bull dog tuner. Air raid cold air intake. AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. Walker 21470 muffler.
Grant
  #18 (permalink)
Old 11-06-2009, 10:51 AM
The eot seemed to be fine during scans but I will try it. Where is it located and can it be uplugged right at the sensor or is it tied into a harness of some sort.
Thanks for the info
Don
  #19 (permalink)
Old 11-06-2009, 10:59 AM
tdpower's Avatar
Here is a pic: http://www.ford-trucks.com/user_gall...184645&width=0
__________________
Grant
Tags
97 , aih , code , diesel , f350 , ford , glow , gpr , hot , pcm , plug , po380 , relay , switch , terminals , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
