Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 09:53 AM
CaptainIPSC CaptainIPSC is offline
CaptainIPSC is starting off with a positive reputation.
help on how to vent the crankcase
I'm all but done installing a 460 in my '78 F250 4X4. What's the best way to vent a crankcase? I have nothing in either valve cover ( grommet wise ) nor do I have an air cleaner. So I believe my options are wide open I just need advise on which way to do it.
  #2 (permalink)
Old 11-02-2009, 06:39 PM
kjett's Avatar
kjett kjett is offline
kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE.
WHat valve covers are you using? If it's a stock type setup that you are running, drill a hole in the driver front and passenger rear covers and put in breathers in each hole.
If it's an all out race setup, drill both rear edges and get you a crancase evac setup from Summit or Jegs, you'll just have to weld in the evac tubes into your headers.
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
95 F-150
1995 F-150
Ranger build: Ranger Mud Truck
http://i209.photobucket.com/albums/b...kjett/baby.gif
  #3 (permalink)
Old 11-02-2009, 07:40 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
if your running mostly a street setup you need to punch out the grommet holes in the valve covers (almost all valve covers have a place setup for this just not always punched or drilled) and run a PCV system. you can either run a line to your air filter or a filtered cap on the other valve cover.
__________________
Rob
Dying's not so bad
It's living that will kill you off
Tags
cover , crankcase , f150 , v8 , valve , vent , ways
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
