Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 09:31 AM
DakotaRiser DakotaRiser is offline
DakotaRiser is starting off with a positive reputation.
Electrical Problem - Starter
I just replaced my starter on my 96 F-250 Crew Cab PowerStroke. When I went to hook the batteries up the #4 Relay (Trailer Tow Lamps) clicks and all four turn signals blink for about 15 seconds and then quits. My starter will not engage using the ignition switch but will engage (and engine will start) when crossing the posts at the starter solenoid inside front right fender. Any suggestions as to the problem? - I am totally baffled and any help would be appreciated. Thanks.
  #2 (permalink)
Old 11-01-2009, 03:32 PM
sg1099 sg1099 is offline
1987 Ford F-150
sg1099 is starting off with a positive reputation.
i hope you didn't switch the cables on the starter.good luck tracing the problem.
  #3 (permalink)
Old 11-01-2009, 03:50 PM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 is gaining momentum as a positive member of FTE.
If you starter has the spade or flat type terminal on it that the wiring plugs into, replace it will a ring terminal directly attached to the starter. That is known for having a bad connection and then the starter will not work.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
  #4 (permalink)
Old 11-01-2009, 06:36 PM
wolfsmurf's Avatar
wolfsmurf wolfsmurf is offline
wolfsmurf is starting off with a positive reputation.
does this truck by chance have or had a security system installed? sounds like the system is armed and in anti-theft mode. if its a factory system just lock all doors and then unlock them with the keyfob or original ignition key. we get this all the time at the parts store after installing a battery, stupid anti-theft.
__________________
ever wonder what a certain word means?
Dodge= Drips Oil Drops Grease Everywhere
Chevy = Cant Handle Even Volkswagons Yet
  #5 (permalink)
Old 11-03-2009, 10:18 PM
Quote:
Wolfsmurf: I thank you for the tip. It worked and the truck is running again. My truck has a Mirage Model M alarm system...didn't know that. But the problem now is that if I leave the doors closed for a while and then open the drivers door the lights are blinking again and I need to hit the "D" on the remote to reset or disable the alarm. I found a small toggle switch and the black programming button underneath the dash but I never had to disarm the alarm before to get it started. I've done everything from opening the locked door with the key to cycling the lock and unlock with the remote and still the system goes into anti-theft mode. Any other suggestions? So far you have helped a lot...someday I hope I can return the favor! Thanks again, DR
Tags
1987 , 1996 , electrical , f150 , ford , problems , solenoid , starter , terminal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
